Front Coil Springs-'98 on '00-will they fit??
Old Sep 14, 2006 | 08:31 AM
JDDinWV's Avatar
I am driving a 2000 Tacoma. I am going to use daystar front spring spacers very soon. I ran across a set of complete struts for a '98 tacoma priced right. If the will fit my truck which is a 2000 model, I will pit the spacers on them and have them ready to install. This is a daily driver, so the less time it's down, the better. I'm not sure whether to go with blocks or shackle on the rear. I haul heavy loads in this truck. The stock leafs are not the best. Anyone found a good way to beef up the springs and get a couple inches of lift? Without spending an arm and a leg??
Old Sep 14, 2006 | 08:44 AM
MTL_4runner's Avatar
Yes, those fronts should work fine.
I'll let others help you out with the rear spring suggestions.
Old Sep 14, 2006 | 12:52 PM
Chainlink's Avatar
I have a 98 Taco lifted via tundra springs in the front and an addaleaf in the rear( blocks suck and on a yota with stock springs more so). The addaleaf leveled me out and works fine but it increased my axle wrap.I am getting a set of new spring packs to help with that, then link it. Blocks are cheap but crap. AAL will work no real troubles I guess but.... If I had to do it over again I would pony up a few dollars more and get a military wrapped set of springs.
P.S. you could get a longer rear shackle also but I have no real expirence with the longer ones(over 1" stock ie: 2",3")
Old Sep 14, 2006 | 01:27 PM
04 Rocko Taco's Avatar
X2. The fronts will work fine.
Old Sep 14, 2006 | 04:03 PM
Albuquerque Jim's Avatar
The deaver add-a-pack is a good addition to stock springs IMO. You can get them through www.sonoransteel.com
kazuya2416
Apr 5, 2024 02:17 AM
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
crashburnoveride
Jul 10, 2015 06:39 AM
Vargntucson
Jul 4, 2015 12:15 PM
