Fresh Tech
#42
What type of toggle/switch could I use? Performance Products sells a Toyota OEM fog light switch which mounts to the left of the steering whell and it even lights up. Would that work? What wire would I need to use? Is there an easy way to splice the wire in?
Thanks!
Thanks!
#43
Originally posted by heliax
Voltage regulator is for??
If the voltage regulator does limit the current, then there's no use in getting a high output alternator to run an onboard welder, stereos, or winches.
Please let me know if I'm wrong.
Steve
Boomer8404
09-17-2015 07:59 AM
