Formula Needed
Old Sep 28, 2004 | 07:52 AM
03TRDBlack's Avatar
Formula Needed
Can someone point me to a formula for calculating the gas mileage with my new tires. I went from the stock 265/70/16's(31")to some 265/75/16's (32"). I know that I travel a bit farther than the odometer says because of the increased size, but I don't know how much. This throws off my gas mileage calculation some because I'm not dividing into the right number. Does anyone know of a formula to correctly calculate the true mileage gone with the bigger 32's so that when I divide by the gallons used it will be more accurate?
Old Sep 28, 2004 | 09:01 AM
mike_d's Avatar
(real miles) = (odometer miles) * (new tire size) / (old tire size)
old tires = (265/25.4*.70*2)+16 = 30.61"
new tires = (265/25.4*.75*2)+16 = 31.65"
(real miles) = (odometer miles) * 31.65/30.61
(real miles) = (odometer miles) * 1.034
that is you're going about 3.4% farther than your odometer reports, and that means you're getting 3.4% better gas milage than you're currently calculating.
edit: that also means you're going about 3.4% faster than your speedometer reports. but since speedometers usually underreport the speed, you're probably right on. i usually double check mine with those radar speed limit signs that have been going up everywhere.
Old Sep 28, 2004 | 09:08 AM
4RUNR's Avatar
Guest
I'm having real doubts about our educational system, judging by how many times this sort of question was asked
Old Sep 28, 2004 | 09:22 AM
03TRDBlack's Avatar
Awesome, Thanks!!
Old Sep 28, 2004 | 02:12 PM
mike_d's Avatar
yeah, i've posted that formula about 3 or 4 times myself. maybe someone should search the posts and just count how many times that's been posted. i'm too lazy to do it myself
Old Sep 28, 2004 | 04:42 PM
4RUNR's Avatar
Guest
I was referencing the formula to find the circumference. I thought it's 6th or 7th grade math
Old Sep 29, 2004 | 09:33 AM
Flamedx4's Avatar
Circumference is diameter * 3.14
If you're talking about tires, it's more accurate to use (static loaded radius*2) *3.14.
Not particularly useful to figure gearing/tire changes or fuel mileage tho.
Old Sep 29, 2004 | 11:40 AM
4Crawler's Avatar
Or since typical odometers are rarely dead accurate, find a stretch of highway with mile markers and drive ~10 marked miles, noting your beginning and ending odometer readings and determine the error. You can do the same to check your speedometer, driving a few measured miles at a steady 60 MPG and recording the transit time.
I have a gear/tire size/speedo calculator page on-line here...
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
Road Bull
Oct 10, 2015 04:55 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
mickyd9990
Jul 6, 2015 09:01 AM
