Extra 12 v outlet
Old 06-30-2002, 05:53 PM
Co-Founder/Administrator
Staff
Corey's Avatar
Extra 12 v outlet
Has anyone added an extra 12 v outlet in the front of their rig?
Rather than fubaring up my factory cigarette lighter so it will have power with the key off, I'd like to add one too the panel where I put the switch for the Warn Power Interrupt kit.
I'd probably use a 30 amp relay under the hood much like the lamps and switches for them are wired up, or I could probably get away with just wiring it directly to the battery with a fuse by the battery. That would be easier.
I'd like full time power up there to run the GPS via the cigarette adaptor I just bought without having to have the key on all the time for it.
Yeah yeah I know, the mods just never stop do they :confused:
Old 07-05-2002, 11:20 PM
Mack's Avatar
I modded one up, I'll have to get some pics for ya.
Old 07-06-2002, 05:50 PM
Mack's Avatar
Thanks Phil I appreciate it.
Old 07-06-2002, 06:40 PM
ckonarske's Avatar
I added two unswitched outlets high on the driver's side kick panel. I wanted to run the GPS cable around the top of the dash to plug it in without the cable hanging down the front of the dash.
Old 07-07-2002, 01:23 PM
mark from uk's Avatar
corey , on the panel in question is a green light is that the switch for the whinch or is that part of the foot well lights you were going to do?
Old 07-07-2002, 01:32 PM
Staff
Corey's Avatar
Hi Mack, looking forward to some pics later.
Chuck that sounds like a good way you did yours too.
Mark, the green light is the switch for the Warn cut off solenoid I wired up a few weeks back.
I should have mounted the switch a few inches lower though as you can't see that the switch is on unless your stoop down.
I may go to a boneyard and look for a panel from a wrecker and re-do the switch so that it's lower.
Or I could use the hole that is there now in the panel to mount the extra cigg outlet.
Hey, that just may work! Then I'll move the switch a little Southward.
Thanks for bringing this post back to the top, you just got my brain in "mod mode" again
Corey
justdifferentials
Just Differentials
06-13-2022 07:40 PM
83yotastockR
11
11-10-2015 06:54 AM
scott90
10-04-2015 09:21 AM
Toys4parts
09-26-2015 01:56 PM
gp66
09-07-2015 08:29 AM
Quick Reply: Extra 12 v outlet
