Engine TOO LEAN! help!
Old 09-23-2008, 10:24 AM
andrewd's Avatar
Ok so i bought this gorgeous 4runner about 2 months ago and it threw a CEL about two weeks ago, diagnosed it and it said the engine is too lean. Now ive read about these supercharged engines and they have problems with this.
Would getting the urd 7th injector kit fix this problem? I am a college student with barley any money to spend so its kind of out of the question.
Im just curious to see if i can just buy a walbro fuel pump or something to fix the problem. Any Suggestions???
Thanks,
Andrew
Old 09-23-2008, 10:31 AM
mt_goat's Avatar
It would be best if you post the actual CEL code you got but basicly if its running too lean you have 2 general options, more fuel or less air. The cheapest way to go would be less air and Toyota even came out with a bigger than stock SCer pulley that limits boost to 5psi IIRC. You could also screw your deck plate in, may help a little.
Old 09-23-2008, 10:44 AM
pfdaxe's Avatar
Yeah. The deck plate mod sure doesn't help and is not needed with the s/c. Cap it off. You'll probably need the fuel mods like everyone else has that's s/charged. Buying just the Walbro pump won't really help if you don't have the larger injectors to deliver the increased fuel and a controller (piggy-back computer) to control it. Post the code your getting
Old 09-23-2008, 10:48 AM
andrewd's Avatar
Okay, deckplate was capped once the light came on so ill get the actual code and post it up
Old 09-23-2008, 10:49 AM
mt_goat's Avatar
I'm guessing you got a P0171, I have gotten that code sometimes when doing a lot of idling at high elevations or rapid elevation changes. I have a A/F gauge, complete URD fuel mods and know that I'm not running too lean during high boost so I suspect (in my case) it is a ECU adjustment issue at low rpms. It only happens to me in the mountains.
Old 09-23-2008, 10:55 AM
mt_goat's Avatar
Another thing that sometimes helps is to check the sensors that help the ECU adjust the A/F ratio, namely the MAF and front O2 (A/F) sensor.
Old 09-23-2008, 11:46 AM
ROOFGOOF's Avatar
Mine read too lean as well...it was the MAF sensor.
Old 09-23-2008, 04:57 PM
andrewd's Avatar
I cleaned the MAF its in good shape, code still comes up and it is a P0171. I am going to check the O2 sensors tonight and will get let ya know.
Also, I am in the foothills of denver and this car is from ohio, so quite an elevation change. Is there any way to tune the stock ECU?
Old 09-23-2008, 05:11 PM
mt_goat's Avatar
You can re-set the ECU memory by pulling the battery cable for about 15 minutes, that sometimes will help it adjust to elevation changes faster.
The URD kit has a way to tune the A/F ratio.
Old 09-25-2008, 08:15 AM
andrewd's Avatar
Okay, Checked the O2 sensors they look good, so I re-cleaned MAF, and tightened all of the fittings on the intake, one I found was a tiny bit loose. Pulled the battery cable and as far as I know the code is gone. Thanks for the help guys!
-Drew
Old 09-25-2008, 09:35 AM
pfdaxe's Avatar
FYI:
To clear a code, instead of pulling a battery cable, just pull the fuse from under the hood for a few seconds. This way you don't have to reset your stereo, clock etc. It accomplishes the same result
Old 09-25-2008, 11:17 AM
ROOFGOOF's Avatar
-Drew
I cleaned my MAF too and reset to battery....it lasted a few days and came back. I replaced the MAF and its been good ever since plus I gained 1-1.5 mpg on hand calculations.
If the CEL comes back, I would bet its the MAF.....
Charecter1
11-06-2023 10:08 AM
icentropy
09-16-2020 02:47 PM
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
Doug4320
03-24-2018 10:11 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Quick Reply: Engine TOO LEAN! help!
