Engine shuts off while on Reverse
Old 01-10-2007, 03:01 PM
Hoowzer's Avatar
Hi!
I have a 98 4runner LTD. Recently I have been having problems with the ignition shutting off while on reverse.
When I back out of the garage, everything is fine. However while I am driving and I back up onto a hill or any other incline - the engine shuts off and I am left with trying to stop my vehilce from sliding into another car using the ebrake until I can start the igniton again.
The igniton starts right back up as if nothing happened. A guy from auto zone said this is typical of older cars...
Does anyone have a similar problem or can provide advice on how I can stop this or repair it?
Thanks
Old 01-10-2007, 05:33 PM
GOH10 Runner's Avatar
i had that EXACT same thing happen to me the other night, i was clueless i mean it started right back up and thank god it hasn't happened again, i want to know what the cause was.
Old 01-12-2007, 06:57 AM
Gerdo's Avatar
That's weird. Never heard of that before. Keep us posted.
Old 01-12-2007, 08:17 AM
04 Rocko Taco's Avatar
Originally Posted by Hoowzer
Hi!
I think that guys is full of *$&%. Typical of older cars? Its a 98, I know of no other 98's that do this. Bad gas mileage, worn parts, and in need of a tune up are things that are typical of older cars, not dying in reverse. Don't ask that guy anything again. ever.
As for any help, does it sputter at all, or just a clean cut off as if you had turned it off? Since it happens when you back up hills, I do wonder if it could be a fuel delivery problem somehow? Or even something as simple as the battery slides a little bit, or something moves, and piches a wire, or shorts out, and dies.
Old 01-12-2007, 11:40 AM
Hoowzer's Avatar
The engine just sort of cut off. There was no sputter and at first I didnt even know the engine died on me until I turned the key in the ignition.
Old 01-12-2007, 11:46 AM
the car simply died, i did not realize it till i tried to give it more gas and it didnt go.
Old 01-15-2007, 04:00 PM
Hoowzer's Avatar
bump
anyone know of any causes or can provide assistance?
Old 07-11-2007, 01:09 AM
DSN46's Avatar
Thread Revival
Did you ever find an answer for this problem?
I know this thread is old, but I"m doing like I should and searching before asking!
Mine just did this yesterday for the first time... not happy about it at all...
Thanks,
James
Old 07-11-2007, 05:14 PM
GhostriderTx's Avatar
Two real left field guesses.
1. I had a similiar problem on a 96 Tahoe. It was a loose coil wire.
2. Not sure why but the first thing that came to mind was fuel filter.
the1998sr5
15
07-14-2020 08:35 PM
ZONAYODA
07-13-2015 07:17 PM
mengquis
07-13-2015 10:39 AM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: Engine shuts off while on Reverse
