Elocker Cable Conversion
Old Aug 14, 2009 | 05:10 PM
crolison's Avatar
So my elocker motor fried so I didn't want to pony up the $$$$$$ to get a new or used motor, they are rare and expensive. So I went ahead and converted it to cable.
So Blair (knoxtaco) and I used a bicycle stem shifter to rotate some welded on bolts to the elocker motor shaft.
I had to cut my t-case shifter and move it over an inch or so so the shifter could clear the bicycle shifter.
We routed the cables right with the e-brake cable and dropped it down right on top of the motor.
Blair fabricated a little bolt on plate for the barrel adjusters to mount to.
Here are some pics of the conversion.
We cut up the side of the motor so we could adjust and attach the cables properly
Here's the shifter
Old Aug 14, 2009 | 05:15 PM
scuba's Avatar
So one of those little paddle things is engage and the other is disengage ?
Looks kool.. How much slack is there for flex though ?
Old Aug 14, 2009 | 05:17 PM
crolison's Avatar
Yeah you flip the paddles back and forth to lock/unlock it. The case on the motor is sealed up now and has been jb welded back together and filled with grease.
We did it on a lift at full droop and it also has more flex in it above that.
Old Aug 14, 2009 | 06:15 PM
SnowRunner98's Avatar
thats a high tech redneck there! serious ya gotta let me know how that holds up, during the torchure testing that you do!
Old Aug 14, 2009 | 06:21 PM
BigBluePile's Avatar
Clever, hope it holds up!!!!!!!!!!
Old Aug 14, 2009 | 06:30 PM
FogRunner's Avatar
I've seen a similar fix done except they used a vacuum driven actuator mounted on the diff. and ran vacuum lines up to the engine and used a pair of junkyard EGR valve solenoids to actuate it.
Old Aug 14, 2009 | 08:57 PM
DIHOWARD's Avatar
You might want to replace those cheap plastic levers with some aluminum shifters. The ones you have WILL break! Trust me, I speak with 20+ years in the bicycle industry.
Old Aug 15, 2009 | 01:35 AM
KrashDH's Avatar
x2. dont slamb those levers...will create a moment those can't handle...
Old Aug 15, 2009 | 04:13 AM
crolison's Avatar
I know, and I can't slam them. The elocker won't engage if you slam them, you have to gently twist them both at the same time while turning to get them to engage. Basically the same thing you have to do with the elocker, minus flipping to levers.
Old Aug 15, 2009 | 05:32 AM
akaphilly's Avatar
nice work.. whats that shifter from. never seen one like that
Old Aug 15, 2009 | 07:06 PM
crolison's Avatar
Bike Stem shifter
Well wheeled it today, c-locker locked and unlocked perfectly. Great not having to get out of the truck and use ascrew driver to lock it.
Great day of wheeling, broke a cv, and saw a comanche get destroyed
Old Aug 15, 2009 | 07:39 PM
Nice
Old Aug 16, 2009 | 08:08 AM
looks like you might have a new avatar! might have to keep that in mind, if I ever get to step up to an e-locker.
Old Oct 20, 2009 | 12:55 PM
camo31_10.50's Avatar
why the hell did you take that approach to that particular part of the trail..from my point of view(which is obviously limited because im not there in person) it looks like you would have been better off NOT going up that embankment?????
i can just see your rig coming down on that pass. front tire and flipping....LOL
Old Oct 21, 2009 | 10:34 AM
crolison's Avatar
There is a rock you can't see, I went a little too left of it....... That trail likes to make tires lift.....
Same spot...
Later on...
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
Truckwithoutaname
Oct 3, 2015 03:41 PM
rmill05
Sep 27, 2015 01:43 PM
Rcbc92
Sep 26, 2015 03:00 PM
