EFI Fuse
EFI Fuse
Hi All:
I need to reset my car to kill the engine warning light..... and I don't know where to find the EFI Fuse... I am in the fusebox but have no clue which one is the efi fuse... any ideas?
Wayne
Wayne
what year? model? etc
there should be a fuse box in your vehicle's engine bay. the fuse box should have a picture of all the fuse locations on it.
and sounds like youre just putting a bandaid on the real problem: go find a code reader and get the problem taken care of.
bob
bob
You could also try disconnecting the negative battery cable if all else fails. You'll have to reset your favorite radio stations and all that stuff, but it should reset the EFI as well.
But ditto on what Bob said - you might want to find a code reader and pull the codes and fix the problem (unless you've already done that and just want to reset the light). The code reader can then be used to reset the CE light (don't know if they all do that, mine does).
Hope this helps,
Merlin
Hope this helps,
Merlin
Originally Posted by Merlin
...you might want to find a code reader and pull the codes and fix the problem (unless you've already done that and just want to reset the light). The code reader can then be used to reset the CE light (don't know if they all do that, mine does).
Reset wise... SOME do, "MOST" even, but not all. You can get a cheapy $30 reader from Harbor Freight that doesn't...
Scotttekoch
09-28-2015 10:30 PM
