ect power switch
Old 09-24-2011, 04:54 AM
Potomacduck's Avatar
I use it once in a while when merging onto the highway.
It allows the engine to rev right up to 5,000 rpm and that helps blow out the carbon from your valves.........much better than a can Seafoam will ever do.
Old 09-24-2011, 09:18 AM
99 sas runner's Avatar
I took mine down the race track 4 times im sure its cleared of carbon
Old 09-24-2011, 11:59 AM
ZUK
ZUK's Avatar
I've been playing with my ECT button lately and I have noticed it does 2 things. It raises the shift point as you know but it also seems to increase the fluid pressure to the clutches which firms up the shift points....less clutch wear I bet but gears are a little grabbier....a good thing actually.
If you are easy on the pedal then the shift points don't seem to be that much different than with the button off. I just leave it on all the time.
Old 09-24-2011, 02:11 PM
BoostedRNR's Avatar
I could tell a big difference when I would use this on my turbo when it was an auto and then I bought my 00 and can't really tell much of a difference at all. Maybe a little firmer on the shifts but that's all I can tell.
Old 09-24-2011, 02:33 PM
  #25
sdsurfer's Avatar
Originally Posted by 96743runner
or if you don't want to turn overdrive off.
like ! ! !
Old 09-24-2011, 08:56 PM
  #26
mine is ALWAYS ON!!! ill be doin a-hundo on the freeway on 37s
Flying91
45
04-11-2024 04:39 PM
okamikai
04-30-2018 10:19 PM
montanatruck
02-26-2017 07:07 AM
94yotaky
07-23-2015 07:50 AM
Johntom240
7
07-13-2015 12:18 AM
Quick Reply: ect power switch
