ebay timing kit has arrived
#27
make sure its a aisin one those are the best or email them where i got mine see if they can sell you what parts you need
#32
Just did mine (belt, tensioners, water pump, Thermostat) I was surprised how easy it is....
BTW pull the tensioner out compress it in a vise and slide a pin in it then reinstall it, dont clamp the boltgs down just thread them in a smidge install belt and then cranks the bolts...
DO NOT pry on the tensioner pulley with a breaker bar the casting BREAKS and then it costs you $65 for a new pulley and you have to wait an additional day...
Water pump leaked at one time it was a OE unit and the belt had 1 major crack 179k miles Dont know if it was the original but buddy whos a mechanic said it sure looked original by the condition... Ehh either way dont have to sweat it now and I searched on this forum for how to and did it so a big thanks to all you guys!!!!
#38
How do you determine beforehand if your water pump has the oil cooler hose running from it. I have a 2000 4runner limited Automatic Transmission. I need to know before I order the kit. Thanks.
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
