E-brake light coming on randomly...help!
Well, lately my e-brake light has been coming off and on. It only happens when I accelerate into turns though, not while braking.
I check to make sure my e-brake isnt set, and its not, so what could be the cause of this? The light usually stays on for 5-10 seconds and goes away on its own.
I know that I need new rotors but would this cause the brake light to come on? It didnt do it last time I needed them.
T-Diddy might need AA counseling (jk) and most likely would win that bet. I'm not a mechanic, but that's what happened to me when my brake fluid was low. You should've bet a 6 pack while you were at it.
You know what, you guys are probably right....I had to bleed my brakes a week ago after putting my 3rd member back on. The fluid didnt appear to be low afterwards so I didnt add any. Can it still be too low even if its right at the max line?
edit: Its not at the max, its right between low and max.
Originally Posted by RTdawgs
brake pads?
add more fluid anyways, see if that helps.
I'll go ahead and add more fluid though....can't hurt. Thanks for all the replies, and Tdiddy....I prolly owe you a beer!
Originally Posted by unr.frosh
I have the same thing in my runner, I jsut figured it was because of the e-brake extender? Does anyone else have the extender and the phantom light?
Odin
07-15-2015 09:28 PM
