E-brake light coming on randomly...help!
Old Jul 27, 2004 | 08:55 AM
Pretacopower's Avatar
Well, lately my e-brake light has been coming off and on. It only happens when I accelerate into turns though, not while braking.
I check to make sure my e-brake isnt set, and its not, so what could be the cause of this? The light usually stays on for 5-10 seconds and goes away on its own.
I know that I need new rotors but would this cause the brake light to come on? It didnt do it last time I needed them.
Old Jul 27, 2004 | 09:00 AM
TDiddy's Avatar
I bet you a beer your brake fluid is low!
Old Jul 27, 2004 | 09:01 AM
NX Tacoma's Avatar
My E brake light always stay's on because I drove 2 miles with my E brake on! OH NO!!!! :pat:
Sorry I couldn't help you out!
Old Jul 27, 2004 | 09:03 AM
havic's Avatar
T-Diddy might need AA counseling (jk) and most likely would win that bet. I'm not a mechanic, but that's what happened to me when my brake fluid was low. You should've bet a 6 pack while you were at it.
Old Jul 27, 2004 | 09:06 AM
amorphous's Avatar
I 3rd that. Check that fluid o' yers!
Ã…
Old Jul 27, 2004 | 09:11 AM
You know what, you guys are probably right....I had to bleed my brakes a week ago after putting my 3rd member back on. The fluid didnt appear to be low afterwards so I didnt add any. Can it still be too low even if its right at the max line?
edit: Its not at the max, its right between low and max.
Old Jul 27, 2004 | 09:18 AM
RTdawgs's Avatar
brake pads?
add more fluid anyways, see if that helps.
Old Jul 27, 2004 | 09:23 AM
UNR.Grad's Avatar
I have the same thing in my runner, I jsut figured it was because of the e-brake extender? Does anyone else have the extender and the phantom light?
Old Jul 27, 2004 | 09:25 AM
Originally Posted by RTdawgs
brake pads?
I doubt its the brake pads, at least I hope....they were practically brand new when I bought it about 10 months ago.
I'll go ahead and add more fluid though....can't hurt. Thanks for all the replies, and Tdiddy....I prolly owe you a beer!
Old Jul 27, 2004 | 09:27 AM
Thats what I thought too at first. I had to disconnect my e-brake to take off my 3rd member awhile ago, and the light didnt start coming on randomly untill after I reattatched it. It's really simple to do though, so I dunno why it would trigger the light. I'm betting its my fluid, I'll fill it up later and let you know if it helps.
Old Jul 30, 2004 | 02:43 PM
mastacox's Avatar
I need help too, my brake light has been on for about a year now, can't figure out what the problem is... Changed the master cylinder, bled brakes, checked pads, can't debug
smthwsn357
May 1, 2024 07:28 AM
Odin
Jul 15, 2015 09:28 PM
TammyMarie
Jul 15, 2015 11:14 AM
Sandman
Jul 14, 2015 12:36 PM
colinmil
Jul 6, 2015 04:03 PM
