dual batteries - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-09-2003, 10:58 AM   #1 (permalink)
dual batteries
Dose anyone know if the stock alternator would be enough to recharge or maintain two batteries.
rugerm44 is offline
Old 11-09-2003, 11:21 AM   #2 (permalink)
Guest
Send a message via AIM to fourunnabilly
What rig are you running?? Do you know the amp output of your current alternator? I can help ya if you give me some specifics...an alternator upgrade would definitely be a good approach any way you look at it.
BIlly
fourunnabilly is offline
Old 11-09-2003, 11:27 AM   #3 (permalink)
dual batteries.
I dont know right this minute but its a 2002 tacoma double cab 4x4 with 3.4 engine.I will probably wind up with a bigger alternator if I can find one that hasnt been rewound and will fit.
rugerm44 is offline
Old 11-09-2003, 11:41 AM   #4 (permalink)
Guest
I gotta run a few errands for the next hour or two, but when I get back I'll check the specs on your vehicle, and help you solve the problem. Talk to you later.
Billy
Old 11-09-2003, 04:31 PM   #5 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
Here's some good reading...
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Old 11-09-2003, 06:54 PM   #6 (permalink)
Guest
ok ruger, i'm back and working for ya...just gimme some time to do a little research.
Billy
Old 11-09-2003, 09:26 PM   #7 (permalink)
Guest
ruger-
I couldn't find the exact specs on your vehicle, but I am guessing that your stock alternator is somewhere around 80 amps. My 03' 4.7L Runner was 90 amps stock. Here are a few options I would recommend, but it all depends on what you plan to use the batteries and alternator for. Tom @ mralternator.com is a killer guy to work with, he should have a direct replacement for your sotcker that rates around 150 amps...he had a 160 for me. That should be plenty to run 2 batteries @ 12+ volts all day long...unless you have some ridiculously huge stereo or a lot of lights, winch, etc. Personally, I'd upgrade the alternator for about $250 from tom, add 2 yellow tops @ around $120 a piece, and a battery isolator for around $100...if this not within the budget or unnessecary, just replace the alternator and add a second battery of your choice. Sorry for the slow reply...hit me back if you have any further questions.
Billy
Old 11-10-2003, 04:48 AM   #8 (permalink)
Thanks for the information. I figured I needed a bigger alternator.Im just not crazy about rewound ones.Im probably going to get one from wrangler power products.They also sell a battery manager system.Thanks again.
rugerm44 is offline
Old 11-10-2003, 04:58 AM   #9 (permalink)
Lucky's Avatar
Send a message via Yahoo to Lucky
Quote:
My Surf has Dual batteries and I think the basic Alternator only puts out about 55 amps or something like that. Both batteries are wired in parrallel because they can use cheaper batteries and maintain a high cranking out put that is required for the Diesel.
I'm thinking of fitting a higher output alternator if I can find one that fits and has the vacuum pump on it for the ADD because with my aux lights on the alternator struggles plus I'm thinking of putting a couple of amps on the stereo which would further strain it.
Any suggestions as to where you can get an uprated alternator from with the vacuum pump would be gratefuloly received.
Cheers
__________________
Andy
1993 Toyota Hilux Surf (Japanese 4 Runner), 2.4 Turbo Diesel, Custom flush mount rear fog lamps, Ring front fogs and spots, Thule Roof Rack, Arrigoni and De Angelis roof rails, Sony Double DIN stereo, IPAQ GPS system.
Lucky is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
dual batteries w/out isolator dfoxengr Offroad Tech 5 02-26-2007 09:47 AM
Dual batteries under the hood BajaTaco General Vehicle Related Topics (Non Year Related) 85 03-01-2006 05:23 AM
Dual Batteries Installation Gangus2006 Vehicle Audio & Home Entertainment 29 06-03-2005 06:31 PM
Dual Batteries Churnd 95.5-2004 Tacomas & 96-2002 4Runners 3 10-02-2003 05:01 AM
dual batteries? doink 95.5-2004 Tacomas & 96-2002 4Runners 5 02-09-2003 09:58 AM
2009 InternetBrands, Inc.
