disconnecting front sway bar temporarily
Guest
so what do you guys do to temporarily disconnect your front swaybar on your 3rd gen?
not talking about quick disco's, i dont have them yet.
what im asking for is what bolts do you take off, what do you tie it to and how, etc.
thanks guys, pictures would be wonderful also!
my end link bolt snapped like a twig when i went to install my disco's. both sides. just take out one side..keep the other one on if you want to get a feel of it on & off road. top nut & nut on the lower control arm. no need to tie anything, as the other side will keep the sway bar located. just make sure you remove the whole link on the side youre taking off. check out wabfab's site for pics...
Location: From San Francisco, but attending school in Pomona CA
hey sean, just unbolt the links from the lower arms, you can use zip ties or bailing wire to tie it up out of the way, or do what i did and just unbolt the extra 4 12mm bolts on the frame and toss it in the garage.. you can make it th cleghorn and back with no front sway no problem, i ditched mine three weeks ago and havent thought about putting it back on.
1 Post
My only thought of only removing one side is that the sway bar is pivoting in its mounts, rubber or poly, alot more that with both sides (normal configuration) I would think that you would wear out your mounts fast.
Guest
ok ill try just one side.
it would only be for an offroad trip, disconnected at the trailhead and then reconnected and the end of the trail while im airing back up i suppose.
Take the end links completely off...don't leave them to dangle or zip tie them up as you are asking to dent/break/gore something important...or there are quick discos...but you knew about those already.
fwiw, I've been running without a front sway bar for months... it adds another level of "fun" when zipping around slow pokes in the left lane on the highway.
09-04-2015 09:27 AM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
Vargntucson
07-04-2015 12:15 PM
