Dim headlight
Old 02-10-2006, 03:01 PM
HaveBlue's Avatar
Dim headlight
Hey, all!
I did some considerable searching and exhausted all my options before posting. This truly has be baffled.
My driver-side headlight is dim. At first I thought it had burned out. But, upon closer inspection, it was just very dim. I replaced the bulb. That wasn't it. I replaced the fuses. That didn't fix it. Now I'm completely baffled. When I replaced the bulbs, I made sure the harness was making good contact. I read a thread that suggested it might be a gound wire. Can anyone tell me what color the ground wire is, please? Or can anyone offer any other solutions?
Thanks!
Old 02-10-2006, 03:13 PM
KyleT's Avatar
check the fuse
Old 02-10-2006, 03:21 PM
Localmotion's Avatar
get the RB harness
Old 02-10-2006, 03:42 PM
Ironmike4x4's Avatar
Originally Posted by HaveBlue
Hey, all!
My driver-side headlight is dim. At first I thought it had burned out. But, upon closer inspection, it was just very dim. I replaced the bulb. That wasn't it. I replaced the fuses. That did fix it. Now I'm completely baffled. When I replaced the bulbs, I made sure the harness was making good contact. I read a thread that suggested it might be a gound wire. Can anyone tell me what color the ground wire is, please? Or can anyone offer any other solutions?
Thanks!
If the fuse fixed it then why really mess with it. It may be more trouble than its worth.
Old 02-10-2006, 04:36 PM
HaveBlue's Avatar
I edited my message due to a typo. The fuse DID NOT fix it. Now I don't trust my mechanical abilities OR my spelling abilities.
Old 02-10-2006, 06:46 PM
Do you know how to use a test light? (Just a more simple way to find out without knowing how to use a voltohmmeter) If so then put it on the power side of the wire and see if the bulb is lit at full power, if not full power then you will have high resistance on the power side, if full power then check the ground side (maybe someone here will have a diagram and point out the ground for you) and see what result you get.
Old 02-10-2006, 09:11 PM
KyleT's Avatar
oops, i missed that i guess.
mine went really dim when the fuse poped once. somehting to do with reverse ground or somehting.
Old 02-10-2006, 09:18 PM
MorphiasX's Avatar
It might be a bad ground. Check the ground.
4banginRunner
11-13-2015 05:23 AM
Chicken12
10-14-2015 03:54 PM
mreagen
10-05-2015 04:27 PM
beltcutter
09-30-2015 06:14 AM
JPV
09-28-2015 03:15 PM
Quick Reply: Dim headlight
