DIFF size
8" 4 Pinion Rear
You need 8" V6 Gears and Lockers for the Rear. You CAN'T use Gears and Lockers designed for the Tacoma/T100/Tundra Rear. You CAN use Gears and Lockers designed for the older 4Runners and Trucks with the 8" Ring Gears as long as they are for the V6 4 Pinion Diff.
7.5" Reverse Rotation Front
You CAN use Gears and Lockers that fit the Tacoma Front Diff for the Front. You CAN'T use Gears and Lockers designed for the Standard Rotation 7.5" Front Diffs.
Hope this helps.
G
Hope this helps.
G
Dr.Z thanks for the reply. the info was just what I need, as Im about to completely regear w/ front and rear ARB's. I dont want the install held up because the wrong gears were shipped.
Thanks AG
Thanks AG
The Taco's and 4Runner's both use reverse rotation gears in the front. The 7.5" gears that they use are not interchangeable with other Toyota 7.5" diffs.
I have never heard anything to the contrary.
G
G
You can use lockers for the standard rotation front ends, either that or my RD90 is really confused. I have standard rotation in my 95 and everyone else with a 96-2002 has reverse, but the same 7.5" diameter and carrier.
The start of reverse rotation in 4-Runners was 96.
