Did I get the correct Amsoil Gear Oil?
Old 09-01-2005, 03:35 PM
2000t4r's Avatar
I just wanted to make sure that I got the correct gear oil for the front and rear diff and the transfer case.
I found Amsoil local so I got it instead of the Redline gear oil.
Thanks
Old 09-01-2005, 03:50 PM
Nic
Nic's Avatar
Yeah, that's it.
I replaced all my gear oil with Amsoil when I bought my truck, including the transmission. I later changed it out for Redline MT90 in the transmission due to the notchy shifting. You didn't state transmission in your post, but I just thought I would mention it in case you have a manual.
Old 09-01-2005, 03:53 PM
2000t4r's Avatar
The reason I didn't post about the transmission is because I'm getting a deal on the BG tranny flush and refilling with the BG synthetic tranny fluid.
Old 09-01-2005, 04:45 PM
garrett1478's Avatar
what store did you find it in?
Old 09-01-2005, 08:46 PM
2000t4r's Avatar
I found it at Vic Hubbard. They have a website Vichubbard.com, but I don't believe that they sell it online though.
Old 09-01-2005, 11:10 PM
Noliwan's Avatar
I replaced all the fluids in my truck to synthetics also-- all Amsoil expect the motor oil-- Using Mobil 1
You have the correct weight/grade gear oil for the front diff. and transfer case--75w-80
The specs for the rear Diff. is 80w-90 but the 75w should work fine...
Here is everything that is in mine...
Transmission 16.0 Quarts ATF D-II or Dexron III Amsoil Synthetic Universal ATF ATF-QT
Transfer Case 1.1 Quarts SAE 75W-90, Gear Oil API GL-4 or GL-5 Amsoil Synthetic 75W-90 AGR-QT
Front Differential 1.2 Quarts SAE 75W-90, Hypoid Gear Oil API GL-5 Amsoil Synthetic 75W-90 AGR-QT
Rear Differential 2.6 Quarts SAE 80W-90, Hypoid Gear Oil API GL-5 Amsoil Synthetic 80W-90 AGL-QT
Old 09-02-2005, 07:30 AM
2000t4r's Avatar
Thank you for your help
Old 09-02-2005, 12:50 PM
2001Millrunner's Avatar
where did you order these stuff? I'm due for a gear lube changes
Old 09-02-2005, 02:18 PM
2000t4r's Avatar
I bought it locally at Vic Hubbard as stated above. They don't appear to sell it online try calling them to see if they would ship it out to you.
Old 09-02-2005, 02:58 PM
hm......I'd have to locate a local dealer then, I've seen people with cars that says "authorized Amsoil distributor" thanks tho.
Old 09-02-2005, 03:15 PM
Lone4runner's Avatar
arent the front & rear 80W-90 and the transfer case 75W-90???
Old 09-02-2005, 03:19 PM
GodwinAustin's Avatar
nope pretty sure that the front and rear diff are also 75w-90
you should be good to go!
Old 09-02-2005, 04:54 PM
2000t4r's Avatar
The rear diff is 80-90 but according to other post that I have read Toyota does that because of dino oil not being as good as Syn oils. Most people that switched over to Amsoil use 75-90 gear oil
Old 09-02-2005, 06:53 PM
also next time buy your amsoil from Bob I think he is a Amsoil dealer!!!!!!!!!!
Old 09-02-2005, 07:58 PM
2000t4r's Avatar
I PM'd bob and he never responded to me, this was over a week ago
Old 09-03-2005, 06:40 AM
heres a stupid question. So how much of the gear lube do most people buy?? It looks as though if i get a gallon of the gear lube it should cover the front& rear diff & the transfer case. its for a 99 4runner
Old 09-03-2005, 06:57 AM
Gangus2006's Avatar
I put 2.6 or so quarts int he rear diff alone. Get about 2 gallons to be safe.
Old 09-03-2005, 07:01 AM
Nic
Nic's Avatar
http://www.4runners.org/articles/difftsf/
Old 09-03-2005, 07:39 AM
cool thanks
Old 09-03-2005, 10:14 AM
2000t4r's Avatar
I bought 6 qts total for front and rear diff and transfer case
smthwsn357
12-04-2023 02:08 AM
XtraCab
04-12-2020 05:25 AM
mskalmus
05-28-2017 07:51 AM
Coreyr384
07-10-2015 11:13 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Did I get the correct Amsoil Gear Oil?
