Dead OBD II?? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-26-2005, 05:04 PM   #1 (permalink)
Sponsoring Member
midiwall's Avatar
Dead OBD II??
So I was out running around watching STFT, LTFT, temp, etc. and then... nothing. My reader just stop showing info.
I reset the reader - no luck, I reset the ECU - no luck, I tried another reader - no luck. The OBD fuse under the hood is fine (in fact, all of the fuses are fine), there's supply voltage across pins 1 & 9 at the OBD II connector...
Any ideas? The ECU is obviously okay since the truck runs...
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 02-26-2005, 05:54 PM   #2 (permalink)
DarylD's Avatar
Hey Mark , Try unpluging a sensor one at a time and see if it will read a code , start with the Map sensor . I've seen this before were a bad sensor caused a problem with the diagnostics . Daryl
__________________
94 4runner 4cyl 5sp, SAS , rear leaf swap ,Fj 80 front axle ,E-lockers
72 Datsun 510 2dr , v6 conversion in progress
DarylD is offline
Old 02-26-2005, 08:43 PM   #3 (permalink)
Sponsoring Member
midiwall's Avatar
Okay, now that was cool. THANK YOU DARYL!
Here's what I did...
- I pulled the MAF and the TPS connections
- Reset the ECU
- Plugged the MAF AND TPS back in
- OBD II connected
But, it's VERY clear that the ECU is VERY busy trying to deal with the flakey sensor. You can watch the OBD tool (a Palm based Auterra) updating it's display maybe one value every 20-30 seconds instead of its usual refresh of five values many times per second.
I had things torn apart yesterday and I cleaned the MAF and had oiled the TB butterfly and associated area. It's possible that there's just crud on one or the other and this'll work itself out.
I played a bit with various combinations of reseting the ECU with just the MAF off, or just the TPS off, and if I had to guess, I'd say it's the TPS. I say that 'cause if I had damaged the MAF, then I wouldn't expect the truck to run.
I can run with the TPS disconnected, but of course I don't expect to be able to run with the MAF disconnected. But, with the TPS disconnected, I still get the sloggy updates through OBD II. Hmmm, that would tend to say that it's the MAF.
Maybe I can find someone who'll let me swap a TPS and/or MAF with them for a test to be sure.
Interesting problem... It shows the multitasking/multiprocessor nature of the ECU.
Anyway... I've got a problem, but I have a process that can help figure out what's up.
Thanks Daryl!
__________________
~ Mark
midiwall is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
OBD II Not Ready dante General Vehicle Related Topics (Non Year Related) 3 09-11-2006 10:28 AM
OBD II scanner-which one do you have? ianshoots 95.5-2004 Tacomas & 96-2002 4Runners 11 08-07-2006 08:26 PM
OBD I or OBD II? fierohink 95.5-2004 Tacomas & 96-2002 4Runners 3 04-14-2005 05:09 AM
OBD II - what do you use? schlopecki 95.5-2004 Tacomas & 96-2002 4Runners 6 03-09-2005 10:40 AM
Best OBD II Reader out there! MTL_4runner 95.5-2004 Tacomas & 96-2002 4Runners 16 01-09-2004 10:28 PM
2009 InternetBrands, Inc.
