YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-09-2004, 02:42 PM   #1 (permalink)
4Runner 4Play's Avatar
Question Couple of questions...
Hey guy's, I just have a couple of questions regarding some threads of the past that I've been reading into. I've done a search and havent really come up with any real answers.
1) Panhard drop - bracket-.... What is the panhard? drop? bracket? what does it do?
2) Birfields.... I know they are one of the major components of the axle, the middle part? should I look into getting some stronger ones?
3) SAWS .... Ok, I first thought that was the short name for sway-aways, but now I know diferently. Shock absorbers? coils? Why are they so sought after?
So yeah, some may say, "He dont know shat!!" but hey, I've learned so much from this forum and I will always want to learn more!! The one and only downfall to yotatech is the fact that my wallet is always empty now :pat: So yeah any advise or info would be awesome. thx guys, and gals, Cheers, Lee
__________________
'93 4Runner, 31'' BFG Muds, K-N Drop-In, Custom 2.25'' Exhaust, Flowmaster 40 series, Deckplate Mod, No Sway-bars Mod, OME Steering Stabilizer, Ome M72F Frt Shocks, SDORI 2" B.J. Spacers, OME 901 H.D. Coils, OME N98 Rr Shocks
Backroads Mapbook =$25.00
BFG Mudders =$450.00
1 Big bag of sunshine =$180.00
Staying on the trail for 5 days with your closest buddies all driving Toyota's =Priceless
4Runner 4Play is offline
Sponsored Links
To remove this ad, register today!
Old 08-09-2004, 03:57 PM   #2 (permalink)
toy283's Avatar
Send a message via ICQ to toy283
On a coil-spring suspension, the panhard rod is the one that runs diagonally from the frame to the axle on the opposite side. It's purpose is to keep the axle from moving side-to-side. Problem is, when you lift a coil-sprung suspension, this rod becomes too short and pulls the axle to the side while at rest. There are two possible fixes for this:
1. A longer panhard rod. While feasible, the panhard rod should be close to horizontal when the vehicle is rest. By using a longer one, it will run at an angle.
2. Relocate one of the brackets. The one on the frame is usually the easiest to relocate or drop such that you regain your suspension geometry and keep the rod as close to horizontal as possible.
You don't have any, at least not by that name. Birfields are a form of CV joint found in solid axle front ends. While similar in design and function to those found in the IFS trucks, they have a notorious weakness that must be addressed when going to larger tires and locked front differentials.
SAW is merely an acronym for a brand-name, just as you had originally suspected. They got their start making swaybars but no make a miriad of suspension components.
__________________
Dave
'84 XCab, blown 283 V8, SM420, dual cases, etc. -For Sale
'01 Subaru Outback
toy283 is offline
Old 08-09-2004, 04:16 PM   #3 (permalink)
Ah.... I see said the blind man....
Just like the title says, Ahhh..... I see. Well thanks for the reply, It totally helped me out. Now I dont feel as dumb
cheers, Lee
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Just a couple of questions Ryan Shear 95.5-2004 Tacomas & 96-2002 4Runners 3 07-20-2004 10:19 AM
a couple questions goatboy22382 95.5-2004 Tacomas & 96-2002 4Runners 2 06-28-2004 02:15 PM
A Couple Questions J Rock 95.5-2004 Tacomas & 96-2002 4Runners 17 10-06-2003 07:35 AM
a couple of questions nolongeraneqaddict 95.5-2004 Tacomas & 96-2002 4Runners 7 07-05-2003 12:20 AM
Couple of Questions!?!? boo204 95.5-2004 Tacomas & 96-2002 4Runners 1 11-02-2002 01:53 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
