Clutch Reserivor Tank Leaking into Cab
Old 04-25-2004, 04:16 PM
toyota884runner's Avatar
My Clutch Reserivor is leaking into to my 4runner. the leak appears to be coming from inside the cab. It leaks fluid all the way down the clutch pedal. It is a slow leak. But i want to get it fixed. Any one know how to fix this?? please help me
Old 04-25-2004, 04:32 PM
seaflea's Avatar
[QUOTE=toyota884runner]My Clutch Reserivor is leaking into to my 4runner. the leak appears to be coming from inside the cab. It leaks fluid all the way down the clutch pedal. It is a slow leak. But i want to get it fixed. Any one know how to fix this?? please help me[/QUOTE
Youre master cylinder is going bad. it will need to be replaced soon. There is realy nothing else you can do. I have tried rebuilding mine, but had no luck.(it went bad within a month) :pat: Replacing it with a new one was my best option. Its not a very hard fix it just takes a bit of patience to bleed the system. Hope this helps.
Old 04-25-2004, 04:33 PM
Nic
Nic's Avatar
It's a good possiblilty your clutch master cylinder needs to be replaced.
I had the same thing happen with my 84 Camry. My carpet is permanently stained because of it.
It turned out that I needed to replace the clutch master cylinder-it was going bad. I tried to rebuild the original, but it didn't work. I ended up buying a new one from the dealership. It was a very easy job to do on my car. I would think it should be fairly simple for a 4Runner too.
Old 04-26-2004, 04:13 AM
what does one of these cost new???
Old 04-26-2004, 07:07 AM
GRNTACO's Avatar
The one for my Tacoma was 2 bills............but it was under warranty.
Old 04-27-2004, 10:54 AM
The Nak's Avatar
Just bought one at the stealership last week, $119. I also needed a new brake booster, anyone want to take a stab at how much the dealer wanted for one new??
Nak
Old 04-27-2004, 01:19 PM
man you got burned. you can get the exact same thing from marlin crawelers for $29 plus shipping. I bet the brake booster cost you $263.71.
Old 04-27-2004, 02:02 PM
Nic
Nic's Avatar
My 84 Camry's booster bit the bullet a few months back. If I remember correctly, it was around $400.00 from the dealership.
I got an aftermarket replacement.
Old 04-27-2004, 11:40 PM
The Nak's Avatar
I got the master cylinder for $119 not the slave, which is $29 on Marlins site. The site shows that the master cylinders for 79-88 are "coming soon". I was pretty bummed for a minute though.
Actually the dealer wants $1100 for a new booster. Needless to say I got a booster and master cylinder off of a '94 for $125 that I think I can make work.
Nak
Old 04-28-2004, 07:50 AM
kyle_22r's Avatar
mine leaks a bit. i'm thinking of going to the junkyard and ripping out out of a newer truck, i don't wanna shell out the $60 napa would want
Eggslinger
06-08-2019 03:32 PM
Road Bull
10-10-2015 04:55 PM
Kalihi,HI
07-09-2015 04:29 PM
Avenged
07-09-2015 07:55 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: Clutch Reserivor Tank Leaking into Cab
