clutch fork pivot
I always used regular high temp dics brake wheel bearing grease. Before I put it together though.
I just went in the garage and took a look at a 3.0 and 3.4 trans. I can reach in through the opening for the clutch fork and touch the pivot with my finger. My trans is on a bench though.
You MAY be able to get in with an aerosol lube straw. Just don't get it on the clutch. Maybe some spray white lithium grease?
You're just going to have to get creative with the room you have to work with. Maybe you can stick something in with a dab of grease on it?
Does it really need to be done?
Just don't knock your clips off the fork or T/O bearing or you will be pulling the trans anyway.
kawazx636
10-06-2021 03:03 PM
primordialbeast117
12-19-2015 12:23 PM
smilen724
13
11-08-2015 04:11 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
