| New! Use your Facebook to securely log into this site, click logo to login |
| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Chipped crankshaft pulley
__________________
99 Tacoma 4x4 |
#2 (permalink) |
you could always braze it or silver solder and it should be good..if you install it without it might be out of balance..just a thought..goodluck
#3 (permalink) |
You wouldn't happen to be talking about the Woodruff Key, would you? I'm guessing not but it does have a smiley profile.
Is the pulley off? How about some pics? I would guess that depending on the location & size of the break that you could get by beveling any sharp edges so that it doesn't wear the belt. Be careful prying on that pulley. It has a rubber isolator between the crankshaft & the outer pulley to dampen vibrations. It can be damaged. I just had mine off. It took a lot of wiggling but finally slid off.
__________________
-Pat _____________________________ 1998 Tacoma V6 4WD Limited 5spd TRD 2nd Gen S/C RC 310cc Injectors Denso IK22 Iridium Plugs Walbro 190lph FP SMT-6 Last edited by MAIS0N; 12-22-2009 at 05:43 AM. |
#4 (permalink) |
Replace it with URD crank pulley. I believe it's cheaper than factory, and gives you some performance gain.
#5 (permalink) |
My thought would be if it rotates and its missing a piece from it, then I would replace it because it could make it vibrate because of missing weight, and eventuall could ruin a bearing or worse let the crankshaft break, but just my thought.
__________________
1985 x-cab 20R-22R 33-12.5 www.whenshtf.com I would rather explain to the judge why my 16 year old daughter shot an intruder, than explain to the jury why it took 5 days of torture for my daughters killer to die "If you are mad as hell and aren't gonna take it anymore, grab your rifle and head outside. If you're the only one with a rifle screaming like a maniac, go back inside. It isn't time yet." |
#6 (permalink) |
ive done the same thing, ive just ran it with no problems at all. but if you got the coin wouldnt hurt to get a new one.
#7 (permalink) |
URD Pulley... I didn't even think about that. Dealers here in my neck of the woods are asking close to $600 new. Toyota of Dallas is about $300 but I'm not sure how customs and shipping to canada work and there's not much at the boneyard. Are essentially all of the 5VZFE's the same or are there some difference albeit minor across the model years and models themselves? It seems there are more wrecked 4Runners than Tacomas but I always wondered about compatibility of these parts. One would think they'd be the same so long as we're looking at a 3rd Gen runner and 1st gen taco.... Can anyone comment on this?
__________________
99 Tacoma 4x4 |
| Tags |
| 4runner, 92, balance, bearing, chip, chipped, crank, crankshaft, edges, puleey, pulley, pully, replace, small, toyota, urd |
