Check engine light on
Old Nov 19, 2004 | 10:55 AM
Mikronized's Avatar
Unhappy Check engine light on
Hey all...
I was driving home from work yesterday and my check engine light came on... I pulled over and looked around and didn't see anything... it still drives fine... I still have to do that blinking light thing to see what code it gives.. but is there anything I should look for right off the bat?
no misfires.. everything electrical seems to still work.. any ideas?
Old Nov 19, 2004 | 11:07 AM
MoveOvr's Avatar
gas cap? did you recently fill up on gas?...my broken gas cap set my engine light once
Old Nov 19, 2004 | 11:14 AM
Mikronized's Avatar
I checked the gas cap... it was holding seal.. it hissed when I opened it.
so I don't think it's that.
Old Nov 19, 2004 | 11:18 AM
VolcomTacoma's Avatar
It might be a bad O2 sensor or something. Just check the code to be sure.
Old Nov 19, 2004 | 11:24 AM
Pretacopower's Avatar
When my MAF and TPS sensors went bad my truck ran fine.
Old Nov 19, 2004 | 12:22 PM
Mad Chemist's Avatar
Got an Amsoil or K&N oiled filter? Could be your MAF that needs to be cleaned.
Old Nov 19, 2004 | 12:25 PM
Mikronized's Avatar
nope.. I'm using a paper filter.
Could it still be dirty?
Old Nov 19, 2004 | 01:12 PM
Maybe, but not likely. I mentioned it because I've known a couple of people that got check eng. lights due to some of the oil from the filter getting on the MAF. You could pull the EFI fuse, which will reset the check engine light, and see whether it comes back on. This would tell you whether it was a fluke thing. Cleaning the MAF with electronics cleaner and the rest of the throttle body would be easy enough to do, isn't a bad thing to do anyways, and you could rule this out.
Old Nov 19, 2004 | 01:15 PM
blink's Avatar
its a needle in a hay stack without the code
Old Nov 20, 2004 | 09:40 PM
obxfishn's Avatar
If you have an Autozone parts store in your area they will check your vehicle with the Actron OBDII reader for FREE!!
Old Nov 21, 2004 | 06:39 AM
CynicX's Avatar
Old Nov 21, 2004 | 09:09 AM
Yoda's Avatar
A 94 is not OBD2, but they should still have a tool to pull the code.
Old Nov 21, 2004 | 10:16 AM
yamarocket630's Avatar
Yeah, it's called a paper clip shorted between E1 and TE1 in the diagnostic connector.
Old Nov 22, 2004 | 10:04 AM
Mikronized's Avatar
ok... it's a code 71... which means something is wrong with the EGR...
we blew into it to make sure it wasn't cloged.. we checked the EGR temp wire with an ohmmeter.. it read really high the first time but then it read normal... we checked the VSV I think it is.. it was fine too.. so I'm still not sure what's going on.
any ideas?
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
