CB antenna mount
Old 10-28-2012, 01:58 AM
99SR5's Avatar
CB antenna mount
Hey all, im planning on installing a CB radio and im planning on putting the antenna on the LR corner of the truck. I was wondering if you guys could post up some pics on how your routed the cable to the mount. i want to make it as clean as possible. Thanks
Old 10-28-2012, 08:19 AM
Inferno451's Avatar
What's it going on?
Old 10-28-2012, 08:39 AM
99SR5's Avatar
3rd gen 4Runner
Old 10-28-2012, 10:27 AM
stockwell45's Avatar
I routed mine through the tail light, into the interior trim sitting above the rear storage space, down along the wheel well (still behind the trim), into the trim for the rear seat belt, into the carpet, under the carpet to the console, under the console into the dash. I had to make a small notch in the plastic on the tail light for the cable to run through. My cable is 12 ft long and I can't squeeze another centimeter out of it if I tried. It's really strained so if your CB is located in the old ashtray location I'd say get a 14 ft cable if you can.
Old 10-29-2012, 06:25 AM
99SR5's Avatar
ok yeah i plan on putting it there. how well is your tail light sealed?
Old 10-29-2012, 08:08 AM
Man4God's Avatar
Subscribed.
Old 10-29-2012, 11:18 AM
Here's some pics I got. After going outside to check it out, I realized I didn't actually notch the tail light for the cable, I notched it to fit the antenna bracket in that location. If you plan on mounting a bracket somewhere else you don't need to cut anything. There is a good gap on the bottom and top of the tail light to allow the cable to be run through.
No leaks, even with the tail light notched. That whole area behind the tail light is pretty well insulated from the weather. Don't mind the body damage, that was from when I flopped my rig and the antenna mount pushed into the body. Hopefully you don't need to worry about that!
Old 10-29-2012, 04:33 PM
habanero's Avatar
Here's a before shot....
I had more coax to work with so it's routed behind or under the trim all the way from start to finish, and through the wiring grommet for the tail light.
I haven't been talented enough to test out side vs mount strength though.
Old 10-30-2012, 04:29 AM
Nuthuts96's Avatar
Location: Shelburne, VT previous: Everett, WA; Bellingham, WA
did it in a similar fashion, but below the light housing. used same mount- works great!
end is routed out of hole on left, with grommet, then routed above housing with wire clip.
only thing i want to change is add a flat metal extender (~2") to get the antenna outside the rear door. in current state, i have to bend the antenna out while opening/closing cargo door.
Old 11-01-2012, 08:17 AM
99SR5's Avatar
these are great, thanks guys its giving me ideas. i appreciate it
Old 11-08-2012, 07:55 PM
Evilmunkey's Avatar
I got mine from a guy/vendor on T4R.Org, I'll post up an updated picture w/ the mast mounted and wiring run (have had it mounted quite some time since I took that photo a few months ago, lol)
Old 11-08-2012, 08:00 PM
uncleblues's Avatar
nice sandals, dude
Old 11-08-2012, 08:49 PM
rokblok's Avatar
Originally Posted by uncleblues
nice sandals, dude
Those are flip-flops....
Old 11-09-2012, 06:02 AM
uncleblues's Avatar
I'm from Michigan...what did you expect?
Old 11-10-2012, 12:21 PM
Evilmunkey's Avatar
well that would explain the inability to enjoy flip-flops, lol
With Antenna Mounted:
live4soccer7
05-11-2016 06:52 PM
scott90
10-04-2015 09:21 AM
zombie_barbarossa
10-02-2015 10:54 PM
voiddweller
10-02-2015 07:47 AM
Brodetski
09-30-2015 11:50 PM
Quick Reply: CB antenna mount
