Catalytic Converter Captive Nuts
I'm going to install a TRD exhaust on the 4Runner tomorrow.
I start PB Blasting stuff this afternoon and there is NO WAY
the intermediate pipe/cat bolts are coming out! They will
need to be cut. Once the heads are cut off I doubt the
remaining portion of the bolt is coming loose either. Has
anyone cut the captive nut off the cat and just run a bolt/nut
through??
through??
If you have access to a torch try heating them red hot and they will back out much easier. If all else fails as long as there is enough room a standard nut and bolt will work.
through??
through??
When i did my test pipe for the intermediate cat replacement i did the bolt and nut method.
kawazx636
10-06-2021 03:03 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Scotttekoch
09-28-2015 10:30 PM
