cant get tires mounted, rubbing issues.
#41
From the pic it Looks like some rubbing issues might be in your future and possibly some body damage in the rear wheel well. Are going to adjust your bump stops ? How close is the front when you stuff it?
#42
Guest
yea the rears rub on the mud flaps... hence the lack of them in that picture.
the rear bumper is mildly misaligned, as the PO failed to keep all the bolts in it. so once i figure out what needs to be replaced i will readjust it all. the left rear rubs just a tiny tiny bit on the filler neck shroud.
the front rubs at full stuff when turned. which on this IFS is not often. all i can see it rubbing on is the valance.
coffey50
07-28-2015 10:55 AM
skoti89
07-08-2015 12:05 AM
