Can you get taller gears for hilux diffs?
Old 10-14-2005, 05:37 AM
thek's Avatar
I'm currently looking at running a hilux diff in my soon to be turbocharged 250cid Cortina.
Apparently theyre a good fit but the 3.7 and 4.11 gearing is way too high for my big torque turbo 250 (with a 3 speed auto).
Ideally I am after something around 3.0: 1. Is this possible? Where? And how much?
Thanks for your time.
Old 10-14-2005, 08:53 AM
Flamedx4's Avatar
There is a 3.54 available for the 8". Next step is 3.90, then 4.10 far as I know.
Might be some better 2wd ratios?
Old 10-14-2005, 09:23 AM
jimbo74's Avatar
my truck is an 8" rear and it has a 3.07 ratio
Old 10-29-2005, 05:28 PM
thek's Avatar
Thanks for the info guys. A 3.07: 1 would be pretty close to what I want.
Is that a common ratio over there in the states?
What are the chances that the gears will fit the aussie hilux diff?
How much do a set of these gears cost from the auto wreckers?
Thanks
Old 10-29-2005, 06:48 PM
Cebby's Avatar
We need to find you the axle code for those gears, or you might be able to buy them new from any number of the gear manufactuurers. An 8" diff in Aus is the same as an 8" diff here.
Old 10-30-2005, 10:43 AM
Flamedx4's Avatar
I wonder if the 2wd Hilux in AUS would have the same ratios as they do here. Seems likely.
jashoeuh
11-26-2017 07:01 AM
jerusry
10-19-2015 05:28 PM
priest16
15
08-06-2015 07:43 AM
yourrealdad
07-29-2015 11:08 AM
Athansinis
07-27-2015 08:38 AM
Quick Reply: Can you get taller gears for hilux diffs?
