A/C Not Working - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-31-2003, 09:57 AM   #1 (permalink)
A/C Not Working
When I press the A/C button on my '91 4R, the little green light comes on, but I don't hear or feel the A/C kick in. No extra "load" on the engine either. Any ideas where to start?
BigGunna is offline
Old 03-31-2003, 10:01 AM   #2 (permalink)
AznSky's Avatar
Send a message via AIM to AznSky
freon?
__________________
Rob
AznSky is offline
Old 03-31-2003, 10:19 AM   #3 (permalink)
Co-Founder/Administrator
Staff
Corey's Avatar
My '91 did the same thing.
Bought it Nov. of '98, and later in the year found out it did not work.
Took it to a shop and they ran the dye through it and found several leaks.
They were fixed, new freon added, and as good as new.
By the way, there is a TSB for our year for the air-con for a unit that is behind the dash that can leak.
You are covered if it has not been done yet.
Mine had been done, so the dealer would not cover it again, and it was one of the culprits that was leaking again.
http://www.alldata.com/TSB/916008_en.html
http://www.alldata.com/TSB/60/91600850.html
See # 3 below.
Quote:
General Recalls
TSB Number Issue Date TSB Title SSCV06 DEC 97 Campaign - Cylinder Head Gaskets
SPAP9610 OCT 96 Campaign - Head Gasket Repair
SSCP01 JUN 93 Campaign - A/C Expansion Valve
Corey is offline
Old 03-31-2003, 10:42 AM   #4 (permalink)
It could be the clutch on the compressor.
Nathan
growinseed is offline
Old 04-01-2003, 07:27 AM   #5 (permalink)
Staff
Corey's Avatar
I'd almost stake my title that you are empty on freon.
Sounds exactly the same as how mine reacted before I got it fixed.
Most air-con shops will test it for free, including the dealer.
If you have a lot of leaks like I did, the dealer may not want to touch it.
They sent me to a specialty shop close by.
I had 4 leaks in all, ands the dryer unit needed to be replaced, and the bill came upto either $400 or $500.
This was my first vehicle with air-con, so it was worth it to me to get it fixed.
Corey is offline
Old 04-01-2003, 08:02 AM   #6 (permalink)
I hope I don't have to spend $400+ to get it fixed! I'll take it to the dealer and see what they say.
Thanks.
BigGunna is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
defrosters not working?? zr222 86-95 Trucks & 4Runners 14 11-07-2006 10:44 AM
Horn not working? help please... YotaJunky Maintenance & Repair Archives 5 05-06-2005 05:41 AM
What I've been working on.... Mad Chemist Early Land Cruisers 46 05-21-2004 08:13 AM
4WD not working NEED HELP fooddude 95.5-2004 Tacomas & 96-2002 4Runners 17 05-12-2004 06:54 PM
need some help working out nolongeraneqaddict Off Topic Talk 3 02-26-2004 04:54 PM
2009 InternetBrands, Inc.
