Broke my ARB locker
thats my next question. When we take it apart, what should a blown seal look like? I mean what should I be looking for if thats what it is? Also how would you prevent this from happening again?
if i had to troubleshoot it, i think i'd pull the 3rd, then hook up some shop air to it and see where the air is leaking from...
i doubt that you'll know how to prevent it until you get in there and see what is leaking and if there are any clues as to why it's leaking.
ok so I got the locker fixed today. The O rings were fine. The copper tubing was placed a little too high, so when we reinstalled the 3rd member the copper tubing got pushed back on to the gears. We figured this out becouse there is a scratch spot on the inside of the diff where it was hitting. The copper tubing has knicks in it like something kept hitting it. This caused vibration and there was a stress tear in the copper tubing right where it exits the 3rd member. I got pics of the copper tubing and I'll post it a little later. But it was an easy fix about 2 hours for the whole thing.
#28
Originally Posted by 00Runner
I think I'll look for an e-locker to swap in.
They have their own problems .. mine was leaking air but still engaged .. vs a e-locker that won't engage if malfunctioning. Which would you rather have on the trail?
again like everyone said this was an install issue .. I don't blame the guy, ˟˟˟˟ happens, he made it right. I got no complaints, just a locker
#29
Senior Member
Exactly, my e-locker hasn't worked in about 3 months......blah!
#30
#31
Senior Member
Originally Posted by Albuquerque Jim
Not exactly true, an e-locker can be engaged and dis-engaged manually if necessary.
Good now I can crawl under the rig and manually enable it each time before I go wheelin'!
#32
#33
S-
Same thing has happened to me.... as we all know... thirds are HEAVY! When I put my 3rd back in my front axle, it pused into the ring and the ring eventually wore away the copper line. No prob to fix though... Pain in the ass to R&R. Grrr... Glad you fixed your problem though!
J
J
#35
justdifferentials
Just Differentials
06-13-2022 07:40 PM
justdifferentials
14
06-11-2017 08:36 PM
Toys4parts
09-26-2015 01:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
