Bog at every shift
Old Oct 22, 2007 | 04:24 PM
tntempest's Avatar
Bog at every shift
Under a good bit of throttle I seem to get a bog at every shift. It is an 02 auto 4x4, with new plugs wires and cleaned mass air. Only known problem is the evap codes, I have tried to dry the cannister out and clean the valves to no avail. If I clear it comes back every third cold start and never sets all the rediness codes for emissions. Could it be in a "safe" mode until all codes set and not adjusting? I am going to take it in to do the timing belt and water pump $479 and have them track down the evap problem, just wondering if anybody has noticed this. I have never seen anyone complain about this bog.
Old Oct 22, 2007 | 10:04 PM
stormin94's Avatar
Shift at higher RPM
Old Oct 23, 2007 | 02:27 AM
tntempest's Avatar
Uh, its an auto. And I can be floored and when it switches gears it will bog.
Old Oct 23, 2007 | 11:15 PM
stormin94's Avatar
You have a sensor that is bad, or something. Sounds like your shift points are off, or maybe it's skipping a gear, or maybe even slipping.
punks_is_4x4
Feb 26, 2016 04:29 PM
Davebarbier
Nov 3, 2015 03:28 PM
Flightguy
Oct 2, 2015 05:34 PM
kbpickens
Oct 2, 2015 03:37 PM
creecher10
Sep 30, 2015 03:27 PM
