best lift to add 35' tires
what would be the best lift to add 35 x 12.5 x 15 baja claw radial tires to a 95.5 toyota tacoma. I figure either pro comp 4' suspension with a 3 inch body lift. A superlift 5' system with a three inch body lift, or a trailmaster 6' system with a 2 inch body lift. Please help i want my truck to have a mean look and not have any rub on my fenders. I am willing to do some trimming if necessary.
:pat:
:pat:
since everyone busted you on the 35 foot remark, i'll give you an answer.
your lift depends on the width of wheel you use. if you use 8" wheels, then you can bearly clear with 6" of lift. for 10" wheels, i suggest atleast 8" of lift. you had still rub on full lock turns and off road. both, you have to hammer the pinch weld down on the inner front fender wells.
i had 12" of lift with 35" and i could still rub at full flex.
btw, superlift does not make a lift for tacoma. it's only trailmaster and procomp. fabtech is suppose to come out with a kit too but it's not on the market.
yeah, check my website out at www.geocities.com/beachtaco
also, check out http://forums.delphiforums.com/tacomaterritory/messages. do a search first before you post. you should find more info about 35" and lift.
holy ˟˟˟˟..........haha........i mean 35'' tires......sorry......thats funny...........so should i go 8'' total lift.....i take it pro comp 4'' with a 3'' body lift wouldnt be enough?
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
