Besides Supercharger how to increase power
none taken at all I know it's a joke when i see one. Hell if I removed the rear seats, took out the carpet, that would probably make a hell of a difference in speed.
Originally posted by Mad Chemist
Lose weight...
Lose weight...
here
Just scroll down.
You could upgrade your exhaust system. Corey has some sound clips on his website of different mufflers.
You could put on a K&N. Lots of people have done this. I didn't because I have heard of people having trouble with their MAF sensor or AFM.
Then there is also the Deckplate and ISR mod.
Hopefully that was some help.
Well, what type of toyota do you have and what engine do you have in it? That'll help get you started. With my 3.0L V-6 I just did intake. nothing special for my engine, get a free flow muffler and cat, intake, ignition, etc.
In that case I would go with the deckplate mod, the isr removal mod, and get either an exhaust system or a free flow cat and muffler. you'll definetly see some improvement from what I've heard.
I think I found the easiest way to gain some power. I'll put on one of these babies, I mean why not it works for all the civics doesn't it....ha ha.
Originally posted by ChitRod
1996 4runner 3.4L
1996 4runner 3.4L
https://www.yotatech.com/~corey/tech...ntake/dr_z.htm
[**edit**] I had originally posted the wrong link above, which is where the comments in later messages came from. "oops"
I did it (I have the same engine/year) using plumbing end-caps and it works great. I'm looking at doing it "cleaner" by re-piping from the MAF to the manifold, but that's mostly just for looks.
Like other folks have said, if you did the Deckplate, Freeflow air filter (Amsoil or K&N) and ISR, you'll DEFINITELY feel it. None of it is hard to do, the only potential worry point is cutting the hole for the deckplate, but if you take your time, you'll be fine.
Have fun!
Mark
Originally posted by mpulver
This is an easy engine to do the ISR mod on, it's very cheap (about $4) and easily reversible. The write-up is here:
http://us.imdb.com/CommentsShow?0322802
Have fun!
Mark
Have fun!
Mark
Yeah thanks Jackass if you don't want to help don't respond. But don't send me to a link claiming it's what I need ant it send me to a review on Jackass the movie.
I'm sure Mark posted the wrong link accidentally. He does that occasionally.
You can find the links to the ISR mod article and the ORIGINAL write up for the DeckPlate mod by the person who pioneered it in my sig down below.
Hope this helps.
Dr. Z
Hope this helps.
Dr. Z
