Axle swap???
Old 06-09-2004, 01:35 PM
standarche's Avatar
Axle swap???
Do you know if a rear axle off a 92 4runner will fit on a 91 pickup....I want to switch it out for the gearing???
Old 06-09-2004, 01:43 PM
Albuquerque Jim's Avatar
A 4Runner is coil sprung and a pick-up is leafs.
However, You could just change out the third member. I'm pretty sure they're the same.
Old 06-09-2004, 02:02 PM
Robinhood150's Avatar
Just switch the 3rd member.
Old 06-09-2004, 02:19 PM
Flamedx4's Avatar
IF they both have the same engine. The V6 thirds are different from the 4cyls.
Old 06-09-2004, 02:42 PM
standarche's Avatar
umm.....changing out the third member sounds great! but what is it?
Old 06-09-2004, 03:13 PM
Flamedx4's Avatar
This part.... (SFWPOH)
Old 06-09-2004, 03:31 PM
kyle_22r's Avatar
doesn't matter if it's v6 or 4 cylinder, they'll swap
Old 06-09-2004, 04:37 PM
standarche's Avatar
So what role does the third member play...if I'm getting the rear axle for the 4.56 gearing(would rather switch the whole thing then tear into it to switch the gears), cause my truck has 4.10 gearing and it's just not working out.
Old 06-09-2004, 07:56 PM
Adam F's Avatar
The third member contains the gears that drives your truck. The driveshaft attaches to it, and the axle shafts connect to it, which in turn are connected to your wheels.
All you do is unbolt the drums/axles at the end of the axles, undo the brake lines, slide the axles out, remove the 12mm bolts that hold the 3rd member in, pull it out, put new one in, installation is the reverse of the removal.
But if you have to ask what a 3rd member is, me thinks you will want to take it to a shop and have it done.
Old 06-09-2004, 07:57 PM
Adam F's Avatar
Also, master shake, if you have a 4wd truck you will also need to swap the front differential as well. It's a little bit harder, but still no big deal.
Flying91
45
04-11-2024 04:39 PM
polo451
13
11-20-2016 07:49 PM
deepmarsh
08-06-2015 03:44 AM
Nailit69
Diesel Swaps
07-21-2015 05:28 PM
yourrealdad
07-21-2015 11:13 AM
Quick Reply: Axle swap???
