Automatic Transmission Sealant Question
Old 11-29-2006, 02:09 PM
4Runnerman's Avatar
Hello all,
I just had my 4Runner transmission fluid swapped for Amsoil at what I thought was a reputable transmission shop because the dealer wouldn't do the swap with Amsoil. I won't bore you with all of the details, but I had to bring the truck there 4 times before they were able to keep the fluid from leaking out. However, I discovered today that they put the transmission pan gasket sealer in the filler tube joint along with the o-ring in order to guarantee the filler tube joint would not leak. I'm wondering if this could cause any problems down the road.
Please advise.
Thanks.
John
Old 11-29-2006, 02:52 PM
MTL_4runner's Avatar
That shouldn't cause an issue unless they used excessive amounts.
.....it will make the pan tougher to get down next time though.
BeMiceElf
10-10-2015 09:40 PM
Poncho0206
07-10-2015 06:21 PM
shar
07-09-2015 12:38 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: Automatic Transmission Sealant Question
