Another wiring question: Help me get a LED working with my locker (schematic attached
Old Oct 4, 2004 | 07:18 AM
rimpainter.com's Avatar
Post Another wiring question: Help me get a LED working with my locker (schematic attached
Some of you may or may not know that I had some struggles with wiring my swapped e-locker. To make a long story short, I finally got it working.
Please take a look at the attached schematic and tell me, based on what you see, if the LED will illuminate when the switch is pressed (to lock the axle). Yes, I know there are better ways to do this, but I am not going to tear my new harness out. So, let me know what you think.
Thanks a ton!
Old Oct 4, 2004 | 07:54 AM
4Crawler's Avatar
I doubt it would work, the LED and resistor will drop the entire 12V supplied and the ECU will get no signal, assuming you get any current to flow at all. Why not just put the LED in parallel with the ECU signal, LED from the switch to ground and a parallel wire (existing,) from the switch to the ECU?
Old Oct 4, 2004 | 08:12 AM
Roger-
If you or anyone else has a quick second to whip that up on paint, that would be great. Wiring is like math to me, I just don't get it unless a teacher can show me what they are doing on the whiteboard.
Old Oct 4, 2004 | 08:29 AM
4Crawler's Avatar
Just hook the other end of the LED to ground and leave the existing wire running from the switch to the ECU.
Old Oct 4, 2004 | 08:39 AM
Unhappy99's Avatar
Be sure to connect the LED + side to the switch, and - side to Ground.
Attached Thumbnails Another wiring question: Help me get a LED working with my locker (schematic attached-1096903058_led_switch.jpg
Old Oct 4, 2004 | 12:09 PM
Gracias amigos. I will give that last schematic a shot.
Old Oct 4, 2004 | 05:47 PM
p1michaud's Avatar
Thumbs up
Hey 96Runner, like Unhappy99 said, make sure the LED is wired correctly. They will only work one way just like a check valve in a hydraulic circuit. I just used a 9V battery and test wich way the LED should be hooked up.
From the battery (+), through the diode (--->|--- ) then to ground.
Does that make any sense to you?
Old Oct 4, 2004 | 06:14 PM
Yeah, you guys helped a lot. For some reason I visualize things backwards sometimes (hence my 3 month e-locker wiring ordeal )
I will tackle this little LED dilemna this weekend.
Old Oct 6, 2004 | 04:08 PM
The LED's are operational. Thanks guys!
Scotttekoch
23
Nov 1, 2021 12:41 PM
bigblue82
10
Jul 6, 2015 08:27 AM
gog1968
Jun 22, 2015 05:55 AM
SnowRunner98
Jun 16, 2015 05:12 PM
Beavah
9
Nov 12, 2013 07:31 PM
