Another bad wheel bearing! why?!?!
Old 01-08-2012, 07:24 AM
2000taco's Avatar
So my 99 tacoma with my 6in fabtech and 35s loves to eat parts and drain my wallet. This will be the 4th wheel bearing i have replaced in the last 5monthes and 3rd CV axle.
The bearings im using are autozones brand. They offered to let me return the old bearing and up grade to a timken with paying the difference of 30 bucks.
Is it worth it? or will the bearing just take a poop like the others?
Does any one else have this problem???
I have almost completely had it with this truck im extremely temped to sell her.
or if there is a way to sas for a reasonable amount...
Old 01-08-2012, 08:24 AM
Teuf's Avatar
A wheel bearing or 2 or 6 isn't bad considering the lift and tires. What else does it eat up?
Old 01-08-2012, 08:29 AM
2000taco's Avatar
I have had trucks bigger and smaller and never had them go out this fast and at $70 a pop plus pressing them out and in and new seals another $75 it's getting rediculas. I just replaced my 3rd cv axle in 2k
Old 01-08-2012, 08:52 AM
Teuf's Avatar
MMMMM bad suspension design I would guess. Putting undue stress on your wheels? SAS it.
Old 01-08-2012, 09:04 AM
4bytruckin's Avatar
whats your wheel offset.
Old 01-08-2012, 09:15 AM
scuba's Avatar
I would A start using a different brand bearing (ie, OEM TOYOTA) and B find a different place to install the bearings.
I've had no issues for the past 30k miles with my 35's. Except for excelerated play in the tie rods.
Old 01-08-2012, 09:19 AM
waskillywabbit's Avatar
The actual mechanics of a bearing aren't rocket science.
Bearing failure is typical a result of improper installation (greasing, seating, torque, preload, etc)
poor/stupid suspension geometry putting undue stress on bearings that they were never meant to endure.
Is it the same side or has it happened to both sides?
If only ONE side, I'd suspect the former, if BOTH sides, I'd suspect the latter.
:wabbit2:
Old 01-08-2012, 09:22 AM
2000taco's Avatar
I can't remember whaty back spacing is its not very offset my wheels are practically in side the body. The bearing set up is a poor design in my opinion.
If I was to sas it should I go trail gear (cost wise don't have a bunch of extra $) and a wagoner d44.
Or would the timken bearing be worth it? I can get it for 30 more
Old 01-08-2012, 09:28 AM
Teuf's Avatar
(See # 7 poster for an SAS) ^5, he dah Man
Old 01-08-2012, 09:36 AM
2000taco's Avatar
I have replaced the driver side 2 times, pass. side 1 time this will be the second. The first time I did the press work. After they went bad again I decided I would let my local napa (who does very good work) do them.
Autozone is letting me do a damaged return on my duralast bearing and pay the $30 difference for the timken, I hope it will hold up. If another wheel bearing goes bad im goin to go insane, pull the torch out and cut the stuff out.
Last edited by dropzone; 01-08-2012 at 02:25 PM. Reason: attempting to bypass the censor
bigjstang
08-25-2021 12:41 AM
jasonty
41
12-23-2018 01:00 PM
Gamble_STi
07-07-2015 07:54 PM
skoti89
07-06-2015 07:45 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Another bad wheel bearing! why?!?!
