Airbox Mod
Old 06-13-2004, 08:21 PM
jethro's Avatar
Airbox Mod
Well I'm a proud owner of a massive 2.7L 4 cyl.
Needless to say I need some power, I dropped in a K&N Filter but then I got inch bigger tires, so that cancelled out. I read this writeup and it seems fairly simple. I noticed it said for the 3.0 V6 Engine. Can I still do this mod to my 2.7 and will I be seeing any significant power gain? I'll cross my fingers!
Airbox Mod
Old 06-13-2004, 10:02 PM
Maddog's Avatar
You can do it to any car with a air box.Every one here will have there own opinion but for me it its worth a try ,it does help a little with throttle response.
I just drilled out my air box.
Old 06-13-2004, 10:10 PM
keisur's Avatar
plus if you decide later you want to blow the money on a K&N kit, the hole in the box won't matter since you'll be replacing it anyway. but my opinion would be to do the deck plate mod, it's like $10 for all the material and the only diffence is that you have a little more turbulence in the stock intake tube than you do in the K&N intake tube.
Old 06-13-2004, 10:11 PM
Mossback74's Avatar
I think there is room to put a deckplate in on the side of your box
Old 06-14-2004, 08:52 AM
ewarnerusa's Avatar
there is room in the front of a 2.7L airbox for a 4" deckplate. I did it to mine when I had one. I would suggest putting one in the front rather than the side, so that the opening is not pointing towards the engine. check the link for pic.
TheBFA
02-15-2020 06:55 AM
voiddweller
53
02-01-2016 05:46 AM
oldblue
09-28-2015 04:07 PM
Project90
09-24-2015 11:40 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: Airbox Mod
