AFM Mod
Old 06-05-2003, 02:34 PM
AFM Mod
I have been looking for an old thread that talked about changing the AFM on the 3.0 for better airflow, I can't find it.
SO I am going to start it up again.
Is there a way to open up the AFM in the 3.0 for better airflow? I have heard about getting one from the SUpra, but not sure about that.
Any Opinions?
Old 06-05-2003, 02:49 PM
HaveBlue's Avatar
The only AFM swap I have heard about was performed on a 3.4L. The person who performed it was Gadget.
Also, doesn't the 3.0 use a VAF? Or am I full of @#$%?
Old 06-05-2003, 02:50 PM
Away
Dr. Zhivago's Avatar
I'd do the ISR mod for the 3.0, along with the Airbox mod. That AFM should flow more than enough air for that engine.
My .02
Dr. Z
Old 06-05-2003, 02:51 PM
Away
It is a Vane Air Flow Meter. You 're not full of #$@%.
Dr. Z
Old 06-05-2003, 05:04 PM
PirateFins's Avatar
The supra afm is for the 22re. The afm from a 82 supra is a dirrect fit plug and play into a 22RE. Can't be of any help for the 6cyl.
Old 02-26-2007, 09:00 PM
co4rnr's Avatar
I feel so bad today b/c I "tried" to clean what I thought was my MAF and pulled out the connections for the AFM. WHile it is torn apart right now, and before I try fixing it, Would the MR2 AFM give me more performance? Where can you get something like that. I am curently living in Denver at about 6000 feet elevation. What is the best course of action?
Old 02-26-2007, 09:01 PM
Elton's Avatar
holy old thread geez its almost 5yrs old
Old 02-27-2007, 04:56 AM
MTL_4runner's Avatar
Is this on a 3.0L with an AFM?
If so, you're not the first person to do that.
Old 02-27-2007, 05:28 AM
co4rnr's Avatar
No, it is on my 22re. I am going to try and solder the conections back together. While I have the black cover off of the top, would ya'll advise adjusting it to run leaner because I live at a higher altitude?
Old 02-27-2007, 06:00 AM
mt_goat's Avatar
Been there, done that. It takes a steady hand and a small pointed soldering tip with thin solder. Make sure the solder doesn't cross the tracks. Good luck.
TheBFA
02-15-2020 06:55 AM
BK2TFUTURE
10-11-2015 08:42 PM
oldblue
09-28-2015 04:07 PM
Project90
09-24-2015 11:40 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: AFM Mod
