98 4Runner Rear Suspension (need photos)
Old 02-20-2011, 09:04 AM
Jeff B. in Michigan's Avatar
Hi,
I never had the rear suspension recall taken care of in my 98 4Runner because I had been running AirLift bags. One of the bags just let loose due to rust on the springs and age.. the a$$ is dragging a lot now. As a result, I am considering having the recall performed.
I searched the forum's and found the recall affects the main rear coil springs and some kind of added spring in the center.
Does anyone have photos of the recall mod after install? If so, can you post them up so I can review.
Thanks,
Old 02-20-2011, 11:32 AM
quicksilvr's Avatar
Originally Posted by TurboQueef
Hi,
Thanks,
Every '96-'98 that I've seen that's had the recall done is simply sitting on new stock springs.
Old 02-20-2011, 11:57 AM
Well I guess I should just have it done then... at least I would get a set of new springs through the deal.
Thanks,
Jeff
Old 02-20-2011, 05:27 PM
brian24's Avatar
Picture: google search factory rear springs
You should be able to do the recall just fine. The dealer will use the VIN to verify you qualify and then do the work for free.
Old 02-20-2011, 05:36 PM
Gerdo's Avatar
It'll look the same as yours except probably a little higher. They only rep[lace the springs and don't add anything.
Sounds like it's time to do a lift!
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
lledwod
08-30-2016 01:03 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 98 4Runner Rear Suspension (need photos)
