'98 4Runner Headlights always on
Old 10-28-2009, 08:43 AM
cgibson's Avatar
Hi
New to the forum, so I'll just introduce myself real quick. Bought my 4Runner in 2003 with 60k on it from the original owner, and its been a great vehicle. I do basic maintenance myself, along with all the regular fluid changes and it is running well today with 180k. Been reading and searching the posts for a while as a guest....alot of great information. Unfortunately, this morning, I got a reason to post.
Woke up and saw my headlights on. Irritated that I had left them on all night, I went outside to turn them off -- and they were off. Switch on and off the turn staulk did nothing. A couple questions:
-Any ideas what this could be besides a faulty turn signal switch? My plan is to buy one and change it out this weekend (I'm driving with the fuse removed now)
-Looking in the Haynes manual, they say you need to remove the steering wheel to get to the switch. A search in the forum claims otherwise -- just a couple of screws. Can someone clarify?
-Assuming I do have to take off the wheel, it seems pretty straight forward, with the exception of using a steering wheel puller. Is there a workaround, or do you really need that tool.
Thanks in advance for any advice.
Chris
Old 10-28-2009, 10:43 AM
98runner210's Avatar
What about a stuck relay? Sounds more like that then a bad switch. I had a bad relay on my foglights. I would come out and find the foglights on and the switch unresponsive. Tapping on the relay would shut them off. Replaced the relay and it fixed it.
Old 10-28-2009, 11:55 AM
cgibson's Avatar
Thanks for the response -- I'll check it tonight and let you know
Chris
Old 10-28-2009, 03:35 PM
cgibson's Avatar
That's all it was! Knocked on the relay and the light went off.
Thanks for saving me a whole lot of work for nothing this weekend.
Chris
Old 10-28-2009, 04:26 PM
No prob, you should be able to match up a relay at a local part store.
Flying91
45
04-11-2024 04:39 PM
BeMiceElf
10-10-2015 09:40 PM
09-04-2015 09:27 AM
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
Quick Reply: '98 4Runner Headlights always on
