96 Tacoma check engine
How about some details on the accident itself? Front end damage? Rear? Etc. my first instinct is to guess something with the fuel system. The sensors can detect something as small as a loose gas cap, so if any damage was done to the EVAP system, even just a cracked line, it could throw the code. Your first step should be to take it by an Autozone (or similar parts store) and have them scan it. Do this BEFORE you clear the code. Write down the code number and description, then post it up in here. At that point, you can clear the code, and it may never come back, but if it IS gonna come back, it most likely won't be immediately, and could take a couple weeks until all the proper readiness codes are set.
steve miller
10-10-2015 01:40 AM
