96' 9th/10th body mounts
Old 01-23-2007, 06:00 PM
toyotaoffroad91's Avatar
im about to order a 1" body lift my my 4runner its a 96 so its missing those body mounts...is it really nessesary to install these for the 70 bucks they cost. will i notice or see a difference?
Old 01-24-2007, 05:39 AM
SLC97SR5's Avatar
I doubt you'll notice a difference by bolting them on, there is a reason they added them to the '97's so you might notice ill effects if you do NOT put them on.
With the 1'' BL you are subjecting the mounts to an increased load and the two additional mounts will help compensate for that.
For the peace of mind, I'd bolt them on there, you don't want to do it twice.
Old 01-24-2007, 01:53 PM
4unner4life's Avatar
You may get away with out having those brackets, but why not and just go ahead and get them to be on the safe side.
Old 01-24-2007, 01:57 PM
yea..i guess i could spend the extra 70 bucks...just cant spend it in the bar first!
Old 01-24-2007, 02:16 PM
KyleT's Avatar
i have been running for 4 mos without them, and i really dont know if they will make a difference, i can feel the body lift though. i will get around to it one of these days, just havent thought about it when messing with the truck.
Old 02-04-2007, 12:28 PM
ok so i goto install them and i messed up one hole becuase i went 1 size to big...no biggie...but the top 2 holes are right next to one the the rectangle holes in the frame so if i drill half of the hole will be in the rectange.......these mounts go right under the rear of the front seats correct??
Old 02-04-2007, 12:38 PM
BajaRunner's Avatar
I believe so. You can see the plugs for them when you take off the side plastic stuff inside.
09-04-2015 09:27 AM
Scotto6591
09-01-2015 03:24 PM
priest16
15
08-06-2015 07:43 AM
yourrealdad
07-21-2015 11:13 AM
jon.r
07-11-2015 03:34 PM
Quick Reply: 96' 9th/10th body mounts
