96 4runner not starting
Old Aug 31, 2006 | 03:51 PM
gonzopb's Avatar
i have a 96 4runner 3.4l and it is not starting. It will turn and i can smell fuel but it seems that it will not fire. occasionally it will try to kick but it can't. i am at a loss so any help would be appreciated.
thanks
brian
Old Aug 31, 2006 | 04:22 PM
rimpainter.com's Avatar
Recent mods, work, sounds worth noting?
What's the history on the vehicle? Mileage?
Old Aug 31, 2006 | 06:15 PM
gregbreakseverything's Avatar
Is there spark? Try disconnecting the Mass air flow sensor.
Old Sep 1, 2006 | 06:07 AM
gonzopb's Avatar
well it has 125k on it. the modifications as of now are trd supercharger, urd fuel system upgrade, cold air intake, headers, exhaust, level 10 tranny, level 10 torque converter.
it was working fine one day then the next day it wouldnt start. is there an easy way to check for spark? recently i had the exhaust welded. it started briefly and it was running very rough.
thanks brian
Old Sep 1, 2006 | 06:10 AM
gonzopb's Avatar
i also recently had a timing belt done. when i disconnect the mass air sensor it does try to kick more then when it is connected.
Old Sep 1, 2006 | 06:25 AM
midiwall's Avatar
Who did the install of the FTC1 (the URD fuel/timing box)? The symptoms sound like the tap into the MAF is shorted or the tap at the crank position sensor is broken.
Old Sep 1, 2006 | 08:04 AM
profuse007's Avatar
inductive timing light or take out one of the sparkplug and literally watch it spark or not.
Originally Posted by gonzopb
it was working fine one day then the next day it wouldnt start. is there an easy way to check for spark? ...............
thanks brian
JF9243176
Oct 8, 2017 04:21 AM
vasinvictor
Jan 20, 2016 12:39 PM
torgeir
Jun 25, 2015 05:26 AM
JF9243176
Jun 24, 2015 04:53 AM
JaredL
Jun 16, 2015 04:47 PM
