95 runner rear window
Old 07-19-2004, 09:10 AM
Blackulua's Avatar
Swicth would not activate window to go up or down.Is it the window relay that giving the problem if it is what do I do?
Old 07-19-2004, 09:22 AM
Cebby's Avatar
Make sure the rear wiper is seated where it should be. If it is hung up, the window won't roll up/dn
Old 07-19-2004, 11:07 AM
FROZEN4RUNNER's Avatar
Do you hear the motor or is there no sound at all. I just fixed mine. Motor gears were stripped. I got a 91 camry rear left window motor. It bolts right in and just wire it in reverse and it works like a charm. A cheap fix for all those who suffer from this common problem.
Old 07-19-2004, 11:44 AM
Astralplane's Avatar
It may sound stupid but check to make sure the tailgate is completely closed, and the window lock button is off.
Old 07-19-2004, 01:18 PM
Robinhood150's Avatar
Lots of times soda and junk will contaminate the contacts in the switch. I usually push the lockout switch and the window switch 10-20 times each and it works again.
Old 07-19-2004, 02:12 PM
KevyWevy's Avatar
yeah check the window lock button
4x4-runner
02-26-2017 06:42 AM
warrenjcarlson
07-22-2016 11:47 AM
voiddweller
19
05-02-2016 09:10 PM
Corey
06-19-2002 11:06 AM
Quick Reply: 95 runner rear window
