89-95 hood question...
Old 04-26-2005, 01:30 PM
BeevDawg's Avatar
ok, I have a 93 4runner and was wondering if the hoods from 89-95 pickups(non sr5) will fit on my rig. This is the hood I want on my runner from hannemanfiberglass.com
Old 04-26-2005, 01:48 PM
aviator's Avatar
Should fit
I think it would fit the front ends were pretty much the same I think size wise. Anybody else got any ideas? Aviator
Old 04-26-2005, 05:43 PM
Silver_Truck's Avatar
pretty sure it will fit...as far as i know up to the doors they're the same
Old 04-26-2005, 06:45 PM
Eric's Avatar
wish they made a carbon hood for the 2nd gens... the stock one weigh's a ton!
Old 04-26-2005, 08:59 PM
Brendan's Avatar
it does?
Old 04-28-2005, 08:57 AM
wynn's Avatar
It does fit
I don't have pics to post (yet) but i just put that hood on my 95. I got the 2 pin version so it still uses the stock mounts. I then put Autofab (polyurethane I think) hoodpin assemblies on the front using the stock rubber-bumper-thingy-socket-hole with some washers I bought.
The only work was using the hole saw to cut for the hoodpins and the rotozip type thing i used to trim the back end of the hood. I had to trim it because it only has two pins you don't lift it staight up and off. For this reason the back of the hood where it bolts to the stock mounts would hit so I had to trim it a bit.
I just need to get it painted now so i don't look like all the prerunners around here with white hoods or fenders on dark trucks.
-wynn
Edit: by the way it has the scoop intake portion cut out
and don't bother with shipping I think it will cost almost as much as the hood.
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
Davebarbier
11-03-2015 03:28 PM
87SR5justin
09-29-2015 02:50 PM
Quick Reply: 89-95 hood question...
