89 4x4 gear ratio
89 4x4 gear ratio
Trying to find out how to determine what rear end gears are in my truck.
It's a standard bed,1989,5 speed straight drive trans. Bearings are going in hogshead and have friend with parted out 1986, 2 wheel drive.Would like to just change it all, if possible. Did they make more than one ratio? Both are 22R.
Some help would be greatly appreciated .
TIA
TIA
Originally Posted by Glenn
4wd and 2wd ratios are different. You probably have 4.10:1. Some 2wd's have 7.5" ring gears, and some have 8" ring gears.
Originally Posted by toy283
4.10 with stock 225/75-15 tires, 4.56 with stock 31" tires.
4.56 and stock 31" tires with the 22R series engine...I don't know if there are many of those from the factory. I think that most of those come with 3VZE engines, if not all of them.
Originally Posted by kyle_22r
i do believe that v6s had 4.56 gears with 31" tires and a manual transmission, 4.88s with auto
Seattle_Sign_Guy
07-12-2015 12:38 PM
