4th Gen Rear brakes
4th Gen Rear brakes
This may be a dumb question, but do any of the 4th Gen 4Runners come with rear disk brakes?
My 96 has a bad rear seal and the oil had destroyed the rear brakes, Rather than just fix it, i thought it may be possible to get 4th Ben brakes and backing plates and have them pressed onto my axleshafts. Then i could have rear disks with stock toyota parts... and a parking brake
Steve
Steve
i don't think anyone has attempted it but i brought it up right after they came out and it died quickly. braking has always been my biggest pet peeve with my 4-runner, i came from a 1990 nissan pathfinder with 4-wheel discs that would stop on a dime compared to my 4runner. i just don't want to convert and lose my parking brake and have to run custom machined rotors. if you go through with this let me know cause i will be right behind you.
Well I am seriously considering trying it, I've got a blown rear axle seal that has saturated the rear brakes, and I think that is the root of my spongy brakes
Steve
Steve,
LC80's had disc's also and they're a lot easier to source than 4th gen parts. Another option is Front Range Off-Road Full Floater kit because it will allow you to mount GM disc's with a parking brake, and of course there's the added benefit of being a FF as well...
Originally Posted by SEAN_at_TLT
Steve,
but the LC 80's have a different rear axle than the 4Runner/Taco, I considered the FROR's FF kit for my Taco, but the 4Runner will remain mostly stock and i'd like to stick with stock Toyota parts if i can. (I have GM brakes on my Taco and i like the Toyota brakes much better.
Plus the 4Runner's brakes (4th Gen) were designed for a very similar vehicle, with similar weights and similar braking power, so the calipers won't be oversized.
I have also considered the Sequoia brakes since they have the same rear disks and calipers as the 4th Gen 4Runner.
Steve
I didn't know they used the same ones on Sequoias, maybe they will be easier to find then...
We get all of our late-model 'Yota stuff from Central Foreign, that is their speciality.
Give 'em a try, ask for Don.
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
