4 Runner rear window probs, HELP
Old Feb 13, 2005 | 01:43 AM
El nigno's Avatar
Question 4 Runner rear window probs, HELP
Well that time has arrived that i have been dreading..the back window has started to sieze up, it wont go down it wont go up then it decides oh maybe i will maybe i wont, does anyone know where to get a decent dissasembly diagram so i can take it to pieces, jump up and down on it then put it all back together again!
Old Feb 13, 2005 | 04:42 AM
Bigblock's Avatar
check your window lock switch right next to your up/down switch.that rear window is one complicated sob.
Old Feb 13, 2005 | 06:05 AM
runner89's Avatar
does it do this at the inside switch and outside at the rear door? Or just one or the other?
Old Feb 13, 2005 | 08:45 AM
eric-the-red's Avatar
If it's the famous 2nd gen window I have the factory manual in pdf format, send me an email address and I'll send it to you. It mostly has electical troubleshooting though.
If it is working some of the time the window regulator probably needs lubed. Put the tailgate down, remove the cover and plastic inside. Then you can see the workings. If you click both side locks to locked, 2 clicks, you can move the window up and down with the rear key switch. Just be careful not to go too far up . Clean and lube everything that moves and see if that helps.
If it's a newer runner, sorry don't know much about them.
Old Feb 21, 2005 | 01:50 AM
El nigno's Avatar
I attempted to dismantle the back door so i could get in and see how the back window works and give it a lube..huge amounts of rust on the plates that push the window upwards..it's nicely lubed but still intermittent both from the inside switch and the rear door switch..i reckon it may be the motor. i thought it may be the relay but i am sure that if it was it would not work at all..Eric do you reckon you could send me that manual in PDF,thanks alot!oh by the way it is a 2nd gen runner, 1994 V6
Old Feb 21, 2005 | 03:54 AM
Chapman88SR5's Avatar
you stole my avatar!
Old Feb 21, 2005 | 08:09 AM
El nigno's Avatar
so i have! i'll change it kazzer.
Old Feb 21, 2005 | 08:15 AM
No problem, pm me an email address, I can't seem to attach files when I try to send email through the forum
Old Feb 21, 2005 | 03:42 PM
now thats better! lol no im jk i didnt care that u had the same one, ive been looking for a new one anyway
4x4-runner
Feb 26, 2017 06:42 AM
warrenjcarlson
Jul 22, 2016 11:47 AM
voiddweller
19
May 2, 2016 09:10 PM
Corey
Jun 19, 2002 11:06 AM
