3rd Gen. runner intake kit questions/suggestions
Old 03-23-2003, 05:22 PM
bolojr3's Avatar
Question 3rd Gen. runner intake kit questions/suggestions
I was looking at the K&N FIPK kit for my 97 runner and was wondering if its really worth all the money? Or has any one just replaced the fliter box w/ a K&N cone filter and does that make a difference. I read about just removing the elbow that goes into the fender but i dont think thats enough & has any one else tried any other brands for cone filters. appreciate the 2 cents
Old 03-23-2003, 05:26 PM
CTB
CTB's Avatar
Gadget did dyno tests with his K&N FIPK and actually had decrease horsepower results. Your best/safest bet is to go with an Amsoil re-useable air filter.
Old 03-23-2003, 05:30 PM
bolojr3's Avatar
is the amsoil re-usable filter a replacement of the stock filter or is it a cone type filter because thats what i'm looking for
Old 03-23-2003, 05:48 PM
CTB
CTB's Avatar
It's just a replacement for the stock filter.
Old 03-23-2003, 06:20 PM
Bob_98SR5's Avatar
Bolo,
Welcome to Yotatech. Is that the sound of your wallet getting lighter?!?!?!
To save you the time and agony reading through the millions of threads on this topic, buy:
1) Amsoil air filter TS-115
2) Amsoil recharging fluid
Yes, its reusable.
I did a write up on the air elbow removal. Click on the link in my sig. Also, check out jalaber's website for the deckplate mod. He has a great write up there.
Also, check out the "Tech" Section as well as using the "search" feature.
Again, welcome.
Bob
Old 03-23-2003, 06:24 PM
Gadget's Avatar
I had installed the K&N FIPK on my 96 4Runner and wish I had not. First I found that it plain sucks as a filter. Hole one up to the Sun and you will be amazed at all the holes in it that are much larger then the dust particals you want a filter to filter out.
Also the FIPK tore a big hole in my inner fender wall where it mounts. I am extreamly upset about that. There have been reports from others saying the same thing.
Finally I dyno tested it and showed a loss of power on my truck. You can stop by my site and check it out if you want. I do not know of any dyno tests of the FIPK on a normally aspirated truck.
The best thing you can do is just remove the elbow and that is good for about 6 dyno proven HP and it is FREE. If you take your truck for stream crossings then you may want to do the deck plate mod instead.
Gadget
www.GadgetOnline.com
Old 04-02-2003, 06:38 PM
Ric
Banned - User requested
Ric's Avatar
ok all, im pretty new, but about the deckplate, im lost, ive seen Beckson site, but do you leave the cap off all the time ? is there a screen ? help me, im lost, i see most of you have it, so it must work, and im always looking for mods, THANKX
Old 04-02-2003, 06:55 PM
azrain's Avatar
I'm happy with mine, but I have to be honest and admit that it is not worth the money. Awfully expensive for something that you can build with a couple of well planned trips to the local Ace Hardware and local speed shop.
Although the K&N filter takes a bad rap from some, I have run them for many many years without a problem, but there are some things that you should consider with the K&N's. Since I run PJ1 filters on my bikes, I have learned that cotton gauze filters need some kind of wrap for heavy dust situations. I run a Pre-Charger on my 4Runner, but on the bikes, I just make a few wraps over the filter with panty hose (yes, the same panty hose you can get in the grocery store, ignore the funny looks...) and I have yet to get a dirty intake plenum. Also, EASY on the filter oil! It doesn't need to be dripping off to be effective.
I have NOT tried the other filters available for the 4Runner, so I could not be an objective judge or commentator on the Amsoil, TRD, etc., so I won't even go there.
Mike
Old 04-03-2003, 06:20 AM
AznSky's Avatar
2 words, DECKPLATE MOD. And yes there is a screen you can put there. And you would leave the cap off most of the time, you'd only cap it when going off-road.
Old 04-03-2003, 06:25 AM
Ric
Ric's Avatar
Toyo_Runner96, thankx,, that explains it, thankx, im thinking about gettin one, seeing that alot of you guys have it, it must work, lol,thankx again
Old 04-03-2003, 06:28 AM
rimpainter.com's Avatar
Deckplate all the way!
Team420
01-12-2021 04:57 PM
1stTimer
07-04-2015 11:56 AM
Niameyrider
06-25-2015 05:50 AM
UKMyers
9
06-15-2002 12:57 PM
westbound
06-07-2002 03:30 PM
Quick Reply: 3rd Gen. runner intake kit questions/suggestions
