3rd gen. rear aftermarket shocks for lift
Ok...looking at a few options with ride reports.
Those using LC coils on the rear who are approaching 3-4 inches have used the following with these results so far:
LC COILS with LC OME shocks (N71E) - report - "a bit stiff " but the coils are being used with spacers too.
LC COILS with LC stock rear shocks - report - decent ride on and offroad, not sure if they limit flex.
LC COILS with N86 OME shocks - report - works well, but limit flex of the coils.
My problem is, my 4inch pro comp front lift may or may not exceed what I get out of the LC Coils I am planning on installing, so I may have to consider a rear 1 or 1.5 inch spacer depending if I end up having front end rake.
Anyone else care to share their LC rear coil experiences and shock combinations?
Whats a boy gonna do ?
my LC coil and shock combo was really stiff when it was new. but has broken in now and is nice, not too stiff, not to soft either. it is niice. it has not seemed to sag at all yet either.
I have the LC Coils with N86's. Ride is realllly soft, probably because both the shocks and springs were heavily used. Flex seems to be limited by the shocks. . here is a pic from this past weekend:
That is just about completely flexed
Stock LC shocks are the way to go. Anything longer and you're gonna have serious issues with the driveshaft interfering with the gas tank skid under full articulation of the rear. I have contact problems even with the stock LC shocks, but my gas tank skid is far more mangled than most.
I got this info from another guy...
Stock 80 series shocks are 13.5 x 23"
13.0" and 21.2" lengths from OME's
So by looking at this the LC shocks look like they should be the best bet with 4-5 inches of rear lift. I guess at this point I will begin my search for the best price in OEM LC shocks. I might see what happens with my N86's too...since they are pretty new.
http://www.sonoransteel.com/rear_shocks.html
For the record, yes, my rear end is very stiff, yet, does not cause any problems with flexibility. Just on-road driving sucks once in a while when you can feel a lot of the bumps in the road.
NC994RUN,
Are these the shocks you are using? If not, can you advise which ones you do have?
Thanks...
According to Steves site:
Stock 1995 Toyota FZJ-80 Land Cruiser rear Tokico shock
48531-69486: Toyota Part Number
Compressed 14.5"
Extended 23.5"
My main concern is to find the correct shock for a long LC coil to avoid any premature damage to the shock upon compression/flex.
ThanX!
Thanks...
Compressed 14.5"
Extended 23.5"
ThanX!
Location: raleigh, nc for school chapel hill, nc for home
The shocks i have are the same part # as you listed (48531-69486) aka the 1995-1997 stock LC shocks.
To prevent from over compressing the shock, you need the extended bump stops that Steve sells http://www.sonoransteel.com/store_su...ump_stops.html
Banned - User requested
does anyone have any tips or tricks when replacing the rear shocks ? Im getting ready to do this, and looking for some ideas to make this as easy and painless as possible, oh yea, we will be replacing the springs at the same time. I do have a 1" bodylift, Im sure that will helpout.
I have the '97 8 wrap 19" LC coils. is this what you have combined with the N86 OME shocks?
I'd be interested to know what year LC Coils you guys are running. When I initially called the Stealership to get price quotes for the LC Coils with part numbers from Sonoran's site, they didn't know what I was talking about! I guess Canadian part numbers are different from the US ones?? Must be metric over here or something! LOL! JK!
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
Vargntucson
07-04-2015 12:15 PM
